Old 04-21-2004, 03:13 AM
The Molinator
Knock Sensors 1 + 2
Do you have to remove the intake manifold to replace these or can you get 'em in 'n out by some trick?
Jim
Old 04-21-2004, 05:49 AM
rufus's Avatar
rufus rufus is offline
I look like Gordon
Try this thread
Hope it helps...
First the smiles, then the lies. Last comes gunfire.
