Old 03-17-2019, 07:47 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Side mirror info required
So I got myself some JDM side mirrors early last year, decided that I should now use them on my NZ New SVX.
My OEMs are a simple "push" to open and close against the car body type.
The JDMs are motor driven, using an extra button that is located in the mirror adjustment button section.
I have confirmed that the JDMs work with 12V (including having the heaters built-in).
But I am at a loss as to how the swivel motor drives should work anyone got a wiring diagram (or is there a module that I need).
BTW I think this was NOT an option on USA models.
TIA
Old 03-21-2019, 03:42 PM
SURTEESS's Avatar
Re: Side mirror info required
Got the wiring sorted for the swivel working - now to start on the wiring harness add-ons.
I would like to swap the glass out on one of the mirrors (it has slight salt/water damage) - does anyone know how to remove the glass from the swivel (U/D/L/R) joint ?.
Old 03-21-2019, 05:25 PM
irox irox is offline
Let us know how you do it. Automatic folding mirrors would be make an awesome upgrade!
