View Poll Results: Preferences and opinions
Keep the JDM BBS wheels 8 100.00%
Go for the HYUNDAI wheels 1 12.50%
Don’t see any figment/ drivability/safety issues 0 0%
Have drivability, handling or safety concerns 0 0%
Multiple Choice Poll. Voters: 8. You may not vote on this poll
Old 03-08-2019, 12:08 PM
Wheel opinion please
Having gone from the original stock wheels to the BBS JDM wheels, I am thinking about fitting 17” 2014 Hyundai Elantra Limited wheels onto the SVX.
I really like their design and have actually fit one from my Elantra onto the polo to check for tolerances. No issues.
They are 17” x 114.3, +52mm offset and 7” wide. Would I be able to use these on the polo without too much negative effect?
The closest size tire would be a 225/45ZR17. Specs are very close to stock and they should fit on the 7” wheel.
Opinions? I like the look of this wheel. Slightly angled spokes, but not so much that they look odd on the other side of the car.
Old 03-08-2019, 02:58 PM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
H6 Fanatic
Re: Wheel opinion please
Yeah looks better than I expected. I don't think I could live with the lack of symmetry from side to side though. I'm sure it's hard to notice, but I would know.
1992 SVX LS-L : King of the Stable
LGT 5MT, ABS Delete, Short Ram Intake, Custom Exhaust, Drilled/Slotted Rotors
1993 Legacy sedan : winter beater, supposedly.
1994 Legacy wagon : future drift car?
1995 Impreza coupe : EZ30++, daily racecar.
1997 Legacy GT : date night rocket?
2003 WRX : future winter beater
Last edited by SoCoNoHa; 03-09-2019 at 02:23 AM. Reason: I was blind but now I see
Old 03-08-2019, 03:57 PM
Blacky Blacky is online now
I see nothing! (in a German accent like Schultz)
That's the ticket! Danke schoen mein colonel.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 03-08-2019, 06:05 PM
Fixed the first post. On my PC, they showed up fine.
b
Old 03-08-2019, 10:40 PM
DallasSVX92's Avatar
DallasSVX92 DallasSVX92 is offline
IMO, I dont think they look good. BUT, to each their own.
1992 SVX LS
2002 Park Avenue
2008 328i convertible
1993 GMC C1500 W/T
Old 03-11-2019, 02:45 PM
WYOSVX's Avatar
WYOSVX WYOSVX is offline
I like the Hyundai wheels; to me they are a modernized version of the stock wheels. They might even look better than the JDM BBS. Not enough so, though, in my opinion, to swap them out. If you do, though, they will look nice.
Old 03-11-2019, 04:20 PM
Terry,
Thanks for your opinion. I had the same thoughts about their design.
I was hoping to obtain a bit of technical insights about the effects on safety and handling with regards to putting a slightly narrower wheel on the SVX.
The tires I choose may be too big for that wheel. But going down to a 215/45R17 would have its own issues. Load rating, Speedo errors, contact area.
Larger wheels are usually wider.
JOHN
Old 03-11-2019, 04:45 PM
WYOSVX's Avatar
Technical insight will have to come from someone wiser than I.
I run 235/45 17 with no issues as far as I know. They are supposed to be the same diameter as stock or very close and you already know there is a diameter comparison chart somewhere out there, maybe one of the online tire sellers.
Sorry I don't have more technical info, I could only speculate.
I've never heard a complaint about tread contact area from anyone running narrower tires but that doesn't mean they didn't have any problems.
Old 03-11-2019, 07:02 PM
John,
Keep the BBS, much better than the Hyundai.
Old 03-12-2019, 08:43 AM
LarryIII LarryIII is offline
John,
I like the stock and BBS wheels better than the Elantra wheels. Also, Rosie says that the Elantra wheels are not bold enough for the SVX. But yours is the only opinion that counts. If you go with the new wheels, I would like to buy the BBS ones from you if you're interested.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 03-12-2019, 11:32 AM
Originally Posted by LarryIII View Post
John,
Larry, you really want to know?
http://www.subaru-svx.net/forum/show...&highlight=Bbs
Old 03-14-2019, 04:13 PM
John,
Did you get my reply to your PM?
Old 03-17-2019, 08:19 PM
WYOSVX's Avatar
For whatever it's worth:
Found this discussion on another forum about tire/wheel size. Might help a little, you probably know most of it and then some:
https://www.wrxtuners.com/forums/f53...ire-faq-19172/
He talks about the effect of width on suspension geometry, mostly more width.
Also, compared on a tire size comparison chart. Stock (per my door jamb plate) compared to the size you mention:
https://tiresize.com/comparison/
215/55 R 16 compared to 225/45 R 17. Diameter 25.3 to 25. Width 8.5 to 8.9. Sidewall 4.7 to 4. Circumference 79.5 to 78.4. Revs/mile 797 to 808.
I compared a bunch of other sizes based on research I was doing today because I have to buy new tires. I looked at other sizes SVXers are using to try and find any complaints. I found nobody really griping about anything but rub with some sizes. My very amateur opinion is that if you drive hard and fast you might notice a slight difference.
