Old 03-04-2019, 01:11 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
rear parcel shelf de-ioniser part
in the link below is the timer unit for the de-ioniser unit that sits on the rear shelf (between the speakers).
The timer unit sits just below the rear arm rest (below the glass) and is held in place by the metal bracket you see in the link.
https://www.jauce.com/auction/373773855
Old 03-22-2019, 04:03 AM
SURTEESS's Avatar
Re: rear parcel shelf de-ioniser part
here is the complete rear shelf .....
https://www.jauce.com/auction/373736987
plus LOTS of other stuff from the same seller -
https://www.jauce.com/user/yktrading_2011?search=svx
