#46
Re: I am ready to blow this car up. Won't start now.
All,
It is snowing again. My question is this. If the car is stuck in reverse, can a flat bed tow truck safely drag the car from the rear tow hooks onto the bed? I need to get this to a garage with a lift, I think.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
#47
I would say no, if its a 4WD then the center drive shaft needs to be disconnected before the front wheels are lifted (what about oil out of rear gearbox?).
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
#48
A slippery snow covered flat bed would work. The wheels would slid and no stress would be transmitted to the driveline. You could use dolleys also. Or being a skier I could suggest making some crud skis to put under the wheels.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, Last edited by Blacky; 02-12-2019 at 12:49 PM. |
#49
Contact a reliable and trustworthy tow truck operator and discuss the problem with them. In this part of the world operators are able to uplift locked and immobile cars including four wheel drives, without damage or a problem. Surely this applies your situation.
#50
Tony as long as you are sure it is in reverse, and not park, without the engine running to produce line pressure, the whole box is in neutral. If it is in park the front wheels won’t turn.
#51
Provided that he has not already done so, after making sure that the hand brake is not engaged, Tony should check and confirm that all four wheels move freely, otherwise his fears regarding towing the car remain valid.
#52
If the car is in reverse and I put a fuse in the fuse slot that disables AWD, will the AWD be disengaged? Other than the dash lights saying it is in reverse, I guess I have no other way to know for sure that it is in reverse. But, yeah, a good tow company has to be able to solve this.
#53
Man am I glad we don't get snow where my SVX is - I could not stand all the issues that this guy is having.
#54
Car was towed away this morning by the guy that is going to do the head gaskets. The car won't start because it is stuck in reverse. He disconnected the shift cable from the gear selector on the transmission and he could not get the gear selector on the tranny to move. The problem is there, not the cable. He is going to put it on a lift to try and see why the selector is seized. Any one see this before?
Also, on the gaskets, can anyone suggest where to buy head bolts? I ordered the Cometic gaskets today.
#55
there have been several subaru techs on here that have said used the head bolts over nothing wrong with them
See this thread: http://www.subaru-svx.net/forum/show...ght=head+bolts . Last edited by svxcess; 03-18-2019 at 09:07 AM. |
#56
I had the engine in my 96 polo completely rebuilt, as a result of head gasket failure, at 125,000 miles. Tom Johnson of AWD, Inc. did a fantastic job and said basically the same thing.
Unless damaged or broken, there is no reason not to use the original studs.They were torqued maybe once in their life, when the engine was built. He has never had to use new studs in any of his rebuilds, including the infamous supercharged “shadow machine” .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-19-2019 at 09:14 AM. |
#57
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by svxcess; 03-19-2019 at 09:20 AM. |
#58
I have the Shadow machine sitting here getting ready to pull the motor
#59
Anyone know where I can get the selector switch (inhibitor switch?) on the tranny?
Will this work: https://parts.annapolissubaru.com/p/...1918AA000.html Or this: https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1 @svxfiles @trevor
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 03-19-2019 at 09:52 AM. |
#60
So the thing that had seized up was the selector switch itself. However, the cable also got damaged in the process. Does anyone have a shifter cable or know where I can get one?
Thread Tools | |
Display Modes | |
