Old 12-10-2011, 09:35 AM
Re: Vexine: 1992 SVX
Originally Posted by SubaruJawn View Post
oh shyt ! i been putting powersteering fluid in !
to late to put ATF in ?
Fix the leak then empty out the reservoir with a turkey baster or a hand siphon pump if you have one. Refill it with ATF.
Old 12-10-2011, 09:41 AM
I'd just fill it with ATF a few times before fixing the leak. The only other ways of getting the power steering fluid out of the lines is a lot less fun.
Old 12-10-2011, 10:11 AM
SubaruJawn's Avatar
SubaruJawn SubaruJawn is offline
got my SVX 12-8-11
Out of curiosity, have you been using ATF in your other Subie's power steering systems?
-I realize the XT6's have the electronic power steering
umm, no i been using powersteering fluid.
i can do that.
EDIT:
just found ATF fluid and filled it up.
Old 12-10-2011, 10:22 AM
subeman90's Avatar
Soobologist
Had a look this morning and I have a.feeling it is more then an o ring. He can check it out when it isn't snowing or so damn cold out.
15 OBW premium w/eyesight
Old 12-10-2011, 11:04 AM
SubaruJawn's Avatar
got my SVX 12-8-11
after putting atf in and drove it to local shop n save it hasn't cried a bit, but steering still jitters.
maybe leaking because of non atf fluid has been it ?
atf is thicker isnt it ?
Old 12-10-2011, 11:11 AM
It's going to leak if it's got a leak no matter what you put in it.
The Jitters are from air entering the system.
Old 12-10-2011, 11:32 AM
SubaruJawn's Avatar
got my SVX 12-8-11
kind knew it would, no magic fluid...
I'll get some more ATF and keep flushing out the Steering Fluid.
i'm guessing the air will work its way out ?
Old 12-10-2011, 11:46 AM
After the exchanging of the ATF in place of the psf, then fix the leak, then you can start working the air out of the system.
Old 12-10-2011, 12:16 PM
SubaruJawn's Avatar
got my SVX 12-8-11
well how much fluid should i run threw it ?
1 maybe 2 qrts ?
Old 12-10-2011, 03:10 PM
What happened to the pictures, too dark now .
I didn't know the Power steering had a cooler?????
IS it wet under the car? Still bet it is a metal line going to the RACK.
don't feel bad , don't beat your self up . the guy at Auto Zone argued with me over the power steering fluid . BTW it is Dactron ATF
Bad spell checker DEXRON
Old 12-10-2011, 03:36 PM
jellybytes2 jellybytes2 is offline
soup IS good food
hmmm? ermm?
'97 SVX 'Brilliant' Reddish
'94 SVX Lagina
'93 SVX Less Reddish
'89 XT6
'08 Impreza
'18 Crosstrek
Totaled
'98 LGT ~180K
'97 OBW ~185k
Sold
'89 XT6
'04 VDC Sedan
Parts
'89 XT6
'96 SVX
Old 12-10-2011, 07:24 PM
dexron 3 or better atf
Old 12-10-2011, 09:57 PM
SubaruJawn's Avatar
got my SVX 12-8-11
Interior:
more eventually
Old 12-11-2011, 11:10 AM
SubaruJawn's Avatar
got my SVX 12-8-11
i have started Vexine's body work.
not yet done, this is just good enought to pass inspection, spring time comes i'll be completing it.
here are some before and after shots
Removed the Oxidation on Headlights
Power steering Fix
Coated with Power steering fluid
Old 12-11-2011, 12:29 PM
Confused again ... Looking at the power steering fix , what exactly did you do? I see a hose with clamp also see a hose with a metal pipe and clamp. I see what looks like a nipple coming out of the bottom of you radiator cooler with nothing attached . Now the body work . What did you use to do that ? Did u back it or just fill it with what looks like Fiberglass impregnated Bondo or we called it Duroglass. My body shop said they no longer weld in new sheet metal . They now cut out the rust and Epoxy Glue in a new piece of either fiberglass or sheet metal .
