How do you remove the crankshaft pulley?
I need to do a timing belt change but I do not know how to stop the engine from turning so that I can get the crankshaft pulley bolt loose. How do you stop the engine from turning to do this? I have read in a Haynes manual that you need to install a special pin/flywheel stopper tool. Do I need this special tool and if so where do I insert it? I have changed timing belts on manual transmission and have just put the tranny in 5th gear and holds it while I get the crank bolt loose.
How do you remove the cranshaft pulley bolt on a Automatic SVX? Thanks, Ken |
I've heard of two methods. One is to stick a flathead screwdriver in the access hole for the flex plate at the bottom of the trans. The other is to use a ratchet and a 2x4 across the engine bay. Put ratchet on crank bolt, brace on the 2x4, then crank the engine. If you choose method 2 wait for others to chime in. It sounds way to dangerous to do with my instructions. Try a search for better directions, they're out there. If you choose method 1 be careful not to harm the teeth on the flexplate.
Changing the timing belt does not require removing the crank pulley.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
oh wait hold on one sec..... are we talking the underdrive pully or the crank shaft pully????
Yes, a vice grip with chain works well. Get a one foot piece of 3/8" rubber tube from the auto parts store as well. Cut the tube lengthwise and use it to protect the pulley when you wrap the chain around it. Works like a charm.
If you use a chain/strap around the pulley, you risk destroying the rubber sleeve the secures the inner portion of the pulley to the outer portion of the pulley. Many people seem to have done it without damaging it, but just wanted to let you know. In my case, the crank bolt was on there so tight (probably from minor corrosion), and the strap method would have definitely destroyed the rubber sleeve. The method that I used to remove the crank pulley bolt is one that I borrowed from svxfiles. Its kind of a nifty method that simulates an impact wrench. All you need is a long (say 16-18") breaker bar and a big hammer. Position the socket on the pulley bolt so that the breaker bar is pointing straight up. Then whack the breaker bar from right to left with the hammer. You have to swing it pretty hard. It took at six attempts before mine came loose, but it worked like a charm. When the bolt comes loose, the breaker bar will swing freely, so make sure that you have something to stop it from swinging into any fragile engine pieces.
and lets not forget that using a actual impact wrench is always the best method as long as its 3/8
I don't think there's room for an impact wrench. At least that's my recollection.
