a little talk about my stock engine.. need some helpp..
so i hav my svx with 228.000 miles on it and its leaking a bit of oil, im just 19 not much of a mechanic, but i love the svx.. i want to rebuild the engine.. what should i approach first in rebuilding it?
Re: a little talk about my stock engine.. need some helpp..
Are you going to rebuild it or just reseal it?
First thing you will want to do is get an engine hoist and go through the process of pulling the engine. After that, it's not all that complicated as long as you have some mechanical know-how, that is if you are just doing a reseal of the engine. Depending on how far you plan on tearing down the engine will determine how tough and complicated it gets... |
well it depends on how much i can spend.. id like to get it done like Cam did on his 11:1 project with new pistons, etc.. how much would u estimate a project like that being? pretty much having a brand new engine..
^ im sure that would cost more alot than your svx
94 Acura Integra GSR 97 Legacy Brighton - EG33 Swap still in progress 03 Silverado 2500 - Duramax |
Somewhere in the $5-7k range, possibly more provided you are doing all of the assembly and installation yourself...
I am about 8500 dollars into my rebuild. She is done waiting for my next day off so she can go into the car. But I went above and beyond on a lot of things. 5-7k is a reasonable estimate for a rebuild. You could probably rebuild the heads, reseal the engine, and replace anything needing it for around 2k.
2k sounds ok.. but im sure i would go above n beyond n fix more things along the way.. did u put in larger heads right? or pistons..?
