#61
Do you think any turbo setup for the SVX will be 100% successful unless R&D'ed professionally by someone and taking into consideration everything starting with the cams duration, high quality internals, lower compression, and proper ECU tuneup? Well you are mistaken! At least i am trying to achieve here something really correct... and BTW stop contradicting yourself...you said that:"Don't you think Subaru did the math ....." and later: "Besides, this is distracting us from noodling a good Turbo setup ...." Man!! you're funny
#62
As for the thing you mentioned about piston design and the effect of hot spots... well I don't think we have a problem here, I have never heard about changing the piston head design would cause any problems whatsoever... If you check what aftermarket pistons are available, some have concave design, other convex designs... plus i will be installing forged pistons, so i don't think i have a problem here. I am just playing on the safe side just in case if, and only if something got really scr***d up inside my engine, i won't have to rebuilt the heads again... you know Well at first we need to check the clearance between valves/pistons, and then we see what we can do
#63
Each part of the engine has been designed to work with every other piece. What it appears you are looking to do is to make things as large (or small) as they can physically be without bumping into something else. That sounds like a path to disaster to me. I don't see the contradicion in my statements. Please explain. |
#64
Reply to ELVIS
Elvis, i meant to say that if Mitsubishi Japan was not successful with the turbo setup of the 3000GT do you think that you can realize that easily with the non-turbo or you can say never turboed EG33 (FROM SUBARU JAPAN i MEAN)? i know some guys did it and successfully but under limited constraints to the stock engine. A proper turbo setup needs other setups to the internals and especially lowering the compression and changing the cams config.
And what do you think the lifetime expectancy of the stock EG33 gone "wild"? (I mean boosted) And we are also talking about a used engine!! And the only disaster i will be facing is that if the cams configuration i am going to attempt have a lower output than expected!! Other than that, it is realistic and easy to achieve! As for the contradiction thing, re read the beginning of your statement and the end of it, you will know what i mean...
#65
lets not turn this into a pissing contest and focus on what we can actually do for an N/A build up. If you do not want to use race fuel adn you don't want to use a stand-alone engine management your best bet would bet you simply uprgade cams.
Good #'s have been tossed around for cam specs, but they are all speculation and estimates... Lets chill on the subject for a little while and see what we come up with when the product is tried and tested Tom |
#66
Speaking about a stand alone... what options do I have at a reasonable price?? I am gonna go with the Z32 MAF and either LAN's 2V4 or the SAFC-2 (recommended by Deruvian).
Any other "reasonable" Stand alones anybody can recommend?
#67
there are plenty of standalone brands to choose from. The only thing keeping me from getting one w/ the tt is that the tunning ivolved takes MANY hours and it comes at a price tag that most people would not be willing to pay
Tom |
#68
550 ft/lbs per second * 60 seconds in one minute = 33,000 ft/lbs per minute. Put a 1 lb weight 1 ft away from the crank on your engine, and you've got a rotating diameter of 6.2832 ft. 33,000 ft/lbs per minute / 6.2832 ft = that magical number 5252. This also explains why horsepower and torque always "cross" each other at 5252 rpm (on a dynograph). And by the way, I highly agree with you on the issue of interference. It's for amatuers. Honestly, just change the belt when you're supposed to and there won't be an issue. You'll get way more power from a much higher lift. I'm going to take Harvey's stance on it though. What Danny wants to do isn't necessarily what Harv or I would do, but it's Danny's "bucket of fish." Last edited by deruvian; 10-27-2005 at 03:19 PM. |
#69
#70
I would guess that it would be compatible with the SVX, since it supports all sorts of line signals. However you should get in touch with Apexi, or a distributor that knows what they're doing, regarding its compatibility with the EG33. |
#71
#72
One was honest to me (Matt Elletson <matte@jrponline.com>) and he told me: "Danny, since your car is not really supported in the US market, our options for managment aren't that numerous. My personal recommendation would be a Greddy E-manage. You can also use the Profec E-01 to help tune the E-manage. And if you are not looking to get that deep into tuning, you could use a A'pexi S-AFC." That was the most honest reply I got!! Anyway Garrett, i will contact Apexi as you advised... will post their reply later. thanks.
#73
The section you can build up is the flat area, between the 4 valves, that fits up into the head, the raised bit. Harvey.
#74
Are you having trouble with the Submit Reply button also, it is so frustrating. Harvey.
#75
I'm talking about using a real large lift. Although, if you went past a 0.8 - 1.0mm increase in lift, you'd probably need to ditch the hydraulic lash adjusters and use a shim-style setup. This would be a fair bit of work and a lot of research. |
