Cigarette lighter removal
Hi,
My lighter is not working, fuse is OK and there is power at the fuse. Can anyone tell me how to remove the lighter body? |
Re: Cigarette lighter removal
First, read my posts in this thread:
http://www.subaru-svx.net/forum/show...hlight=Lighter If you have small hands, you can reach the screw-on nut that holds the lighter assembly against the back of the trim piece. You have to raise the audio door and remove the ash tray. You can find the nut and power wires by feel. Once the nut is unscrewed, let it slide back down the power wire so it doesn't get lost. carefully pull the assembly out through the front. See if the fusible link has melted on the back of the lighter. Replace the assembly, plug in the power wire and slide the nut back into position and tighten. You cannot remove the lighter trim piece without breaking it; it is screwed in from the rear. .
Hi,
Thanks for the help, but that is much too small a place for my hands, so I have abandoned the attempt. I will find out what my friendly Subaru dealer will charge instead. |
Or hire the skinny 10-year-old in your neighborhood... Seriously, if you had a pair of 90º long needle-nose pliers, you could grab the end of the nut and break it loose. It is just a thin piece of stamped steel with a lip than you can grasp. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-09-2013 at 10:37 AM. |
