Old 07-18-2007, 11:05 AM
Guyver280z's Avatar
Guyver280z Guyver280z is offline
Send a message via MSN to Guyver280z
Custom exhaust
Hey there, well yesterday I replaced my stock muffler with a Flowmaster (the one used for Camaros, one inlet and two opposed side outlets) and two dual tips and I'm very happy with the results. The car sounds great, deep and throathy. But then I saw that the existing exhaust system have like 4 cats well, two cats comming from each head, and then a Y pipe that goes to another two... resonators?? Cats??
Well, the thing is that I want my car to be a bit louder but I dont want to affect the pitch tone so Im thinking of getting rid of the whole system and make my own custom piping. But I want to hear some opinions first.
I was thinking... Make new pipes coming from the manifold, with no cats, then get a Y pipe and then a high flow catallitic converter and just go all the way back to the flowmaster. The question is, should I put the O2 sensor before or after the high flow catallitic converter?? Or should I use or not the cat and just let the entire system with a free flow?? Or should I use two high flow cats and then the Y pipe???
Suggestions??
Old 07-18-2007, 11:23 AM
I would imagine your SVX is from 92-95?? Meaning it is OBD I correct??
If so, then make 2 pipes w/ 02 sensors into a high flow 2 in 1 out cat. Then through a single straight through resonator and then back to the muffler... Send a PM to svxfiles (original Tom)... he knows a couple great setups for the SVX in several different stages
Old 07-18-2007, 11:26 AM
Kelvin Kelvin is offline
Banned
All SVX's have 3 cats. Two right after the manifolds, and one 2-1 cat. The last part you see is a resonator.
PS: Where are you getting the exhaust work done? I took my SVX to over 10 shops, and all of them quoted me over $700 for simply fixing the 2-1 cat.
Old 07-18-2007, 11:40 AM
Guyver280z's Avatar
I got the Flowmaster, two dual chrome tips and 3 pieces of custom piping all installed for only $400. Got everything done in 30 minutes.
Its called America Mufflers, 255 E Southern, Mesa AZ. they are 2 mexican guys, but I can hook you up.
Old 07-18-2007, 11:52 AM
Guyver280z's Avatar
Yes indeed, 92. ODB 1
I've never seen a high flow 2 in 1 cat. Where can I get it?? and what kind of resonator?? What happens if I dont use a resonator?? Is it going to sound like a Honda??
Old 07-18-2007, 12:15 PM
XT6Wagon XT6Wagon is offline
www.jegs.com usualy has 90% selection of anything that exists as far as exhaust parts goes. close to 100% on common stuff.
If you want quiet, I advise two "resonators" or drilled core glasspacks of different lenghts, and one muffler. Doing this allows one of the N1 style ricer exhausts with all straight through mufflers/resonators to be quieter than most companies "quiet" systems with a single resonator, and a restrictive baffle muffler and small tips. Or atleast it does on a WRX/STi.
The principle is that the two resonators/glasspacks of different lengths prevent the exhaust from resonating at one specific rpm band. If that happens, you don't enjoy life. The wrx I had back in the day was loudest at 2,500-3,000 IIRC, but it was without a doubt louder at that certain rpm band at part throttle, than it was a redline at WOT.
Old 07-18-2007, 01:19 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
You definitely don't want to remove the two secondary cats without replacing them with some sort of resonator - been there, done that, and you end up with a nasty resonance at ~2800 rpms.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-18-2007, 01:36 PM
Guyver280z's Avatar
-Bill
I get it, so what kind of resonator you guys recommend?? A universal resonator??
Old 07-18-2007, 04:32 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
-Bill
WHAT? I CAN'T HEAR NO STINKING RESONANCE WITH OUR 6 INTO ONE HEADER Without cats!
