Old 03-05-2018, 08:33 AM
Huskymaniac's Avatar
Uses the ignore feature
Sunroof seal
My seal is coming loose. How does it attach to the moving part? Does it press fit into it or is it put on using an adhesive?
Tony
Old 03-05-2018, 01:47 PM
oab_au oab_au is offline
Re: Sunroof seal
Just a press fit.
One Arm Bloke.
Tell it like it is!
Old 03-05-2018, 05:39 PM
Re: Sunroof seal
So, if mine is coming off, does that mean it is broken in some way. Is there some rubber stuck in a groove or something like that which I will have to remove before replacing the seal?
Tony
Old 03-08-2018, 09:48 AM
Re: Sunroof seal
I could really use an answer on this question if anyone knows. If there are pieces stuck in a groove somewhere, I will probably use a rubber adhesive to stick it back on versus pulling the whole damn sunroof off the car.
Tony
Old 03-08-2018, 01:00 PM
SVX_MY_BABY's Avatar
Re: Sunroof seal
The sunroof just unbolts from the mechanism.
The seal isn't much diff. from the main doors seals. Just pressure fit. Been too long for me to remember if there is a tongue & groove. I can tell you that the seam between the two ends should be at the rear. When I had my car painted the shop put it on backwards and it only took a few minutes to remove & reinstall.
Peter
Old 03-08-2018, 04:41 PM
Re: Sunroof seal
65441PA002 (65441PA000; 65441PA001)
$175.00
The seal is one continuous strip. Start at the center of the rear of the sunroof and press it into the groove slightly all the way around. But the time you get around the whole way you want slightly more rubber left over than the space you have to cover (maybe an inch).
Then butt the two edges together tightly and push the excess into the groove (in effect compressing it)
If you stretch it to fit, it will soon return to its unstretched state and leave a gap between the ends.
It may take a couple of tries to get it right
Old 03-09-2018, 07:17 PM
Re: Sunroof seal
OK, going to give it a try.
Tony
