Old 08-01-2009, 12:33 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
click click click...start? click click start!
so i turn the key to start my baby and she clicks...is it starter? starter solinoid? ignition switch?
help please..sorry if this is a repost..i cant search the message archives for some reason? help there too? running vista32 bit with IE8
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 08-01-2009, 12:50 PM
Re: click click click...start? click click start!
search "how to do the bosch relay mod"
Old 08-01-2009, 08:42 PM
This will probably overcome the fault. But as I have advised many times, will not fix it. N.B. Refer last page, current post, "Lets talk about this annoying hot start problem".
Old 08-01-2009, 10:34 PM
kwren's Avatar
kwren kwren is offline
The Bosch relay has started my car several thousands of times without fail since I did it! There is no other known solution to this problem.
If this is not a "fix" it is danged close!
Cheers, Trevor
Keith
Old 08-01-2009, 10:36 PM
kwren's Avatar
However...
We pray a lot!
Keith
Old 08-02-2009, 12:02 AM
Originally Posted by kwren View Post
However...
We pray a lot!
Keith
That the existing fault will not develop further, on a cold and rainy night.
Old 08-02-2009, 05:28 AM
Manarius's Avatar
Manarius Manarius is offline
Yeah, I put in the Bosch Relay and still have clicking problems with hot starts . Could be that the relay went bad though...
-Jason
-Obi Wan Kenobi
Old 08-02-2009, 10:56 AM
Francis Francis is offline
my sunfire did this to me . the problem was a loose cable that goes to the starter...have an eye
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
Old 08-02-2009, 05:26 PM
kwren's Avatar
That and a lot of other things, friend!
However, with the Bosch relay sitting there, easily assessable when I open the hood, a simple screwdriver touching across the 2 Bosch relay terminals with the key turned on to the run position and the SVX in park, providing the instant start! Another praise the Lord! on the road again.
Trevor, I am just dying for the day that you hop in your SVX and start the engine, rather try to start the engine and you get the click that so many of the rest of us have experienced! Not wishing you any bad luck because this is one of the cheapest and easiest mods possible.
When this happens, please take your camera to the auto parts place and get us a picture of you standing at the counter with a Bosch relay in your hand and give us a big smile while the camera clicks away. Another "not so bad click".
On your post, please end with... Please see attachment! Cheers, Trevor!
Keith
Old 08-02-2009, 06:14 PM
Well then, lets go ahead and recomend a full harness replacement of everything related to the starting system to get it done your way. That won't cost thousands of dollars or anything.
Old 08-02-2009, 06:33 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
How about we recommends that da guy cleans both ends of his main starter cable, then if that doesnt work, pull the starter and bench test it.
Old 08-02-2009, 11:37 PM
kwren's Avatar
Sorry, a full harness replacement will not fix the fault, and finding everything related to the starting circuit might be an impossible task.
Keith
Old 08-03-2009, 05:46 AM
dcarrb dcarrb is offline
With so many cars apparently having this trouble one might think that someone would have isolated the culprit by now.
dcb
Old 08-03-2009, 02:57 PM
Best to take the logical approach and properly check for voltage drop, all along the tenuous electrical path involved, which includes many sets of interlocking control contacts.
Old 08-03-2009, 03:37 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
??? Which car are you referring to? The main cable goes directly to the starter from the positive battery post. Bosche relay mod aside, from the very fact that the starter clicks when the key is turned means its getting the proper 12V signal to the solenoid.
Two main things remain when you have a starter click but not turn the engine: Dirty contacts not allowing enough amperage to turn the flywheel, or a bad starter. I have seen both many times, thats why the next logical step is to clean contacts, then bench test the starter.
Ahhhhthankyou!
