New Noise.. . Driveshaft Slap!
Evidently, when the muffler man welded in the rear cat, he pushed in the sheet metal cover under the exhaust pipes, protecting the driveshaft. So, when I would turn the steering sharp to either side and accelerate (eliciting the bad axle click noise), it would evidently cause some engine/AT movement slightly.. . CAUSING THE DRIVESHAFT TO HIT THE SHEET METAL COVER .. . making my SVX sound like an old delapidated jalopy with a bad muffler.. . hanging down loose.. . and banging back and forth into various other metal parts [like banging a large screwdriver on a metal trashcan lid]!
Is there a way to diagnose the driveshaft (propellor shaft) center bearing? It didn't seem bad. When I grabbed the shaft and shook it.. . It only seemed to wiggle about 3/16 to 14 inch! The reason I wonder about the center bearing is that when the shaft would hit the sheet metal.. . It would sound like something banging repeatedly (rather than just scraping smoothly).. . like maybe the bearing was "floppy".. ?? Oh..BTW.. . I bent the sheet metal out slightly away from the driveshaft.. . SO, it doesn't make that dreadful noise anymore (but I still get the front axle clicking that I brought up in another thread.. . Waiting for my Chinese axle coming from Mike). I can't tell which front axle is bad, since it makes noise while accelerating/turning in either direction??? Thanks! Jim
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! |
Re: New Noise.. . Driveshaft Slap!
Should of had "The muffin man" do the welding or toasting, sorry that doesn't help does it, but your discription of the noise had me lol. I know nothing about drivshafts beside the ujoints.................G
I thimk ther4 I an, what? huh! 03 Baja. 05 Baja turbo 92legacywagon"snow" 94legacywagon"whinny" 84Brat"huey" 92svx"samantha".pearl 92svx"sabastian"4.44 silver 92svx"sabrina".ebony 05legacy gt limited "Moon" blue. 06 Subaru legacy gt limited. |
