FWD and no light
Damn.
My car is giving such a pain I might just throw it off a cliff. Not that it aint running. But tonight I went around a bit and it was raining. I've driven my car on gravel yesterday and i know for a fact that it was AWD. But now, it shifts on its own, even in 'manual' mode, and 1st gear.I have to stop, get it through all gears from P to 1 so it finally does what I ask from it.But not only that, I had front wheel spin with absolutely no assistance from the rear wheels,and no lights on the dash. What would cause that? Drive axles failure?Computer crap?Bad diff? There is no noise coming from the back, although I heard ONE clunk today, and it wasn't that bad.This car has about 160000 miles on it and its acting weird on me EVERY DAY! |
Re: FWD and no light
One possible cause is your rear clutch drum in the back of the tranny has sheered off from the shaft. You wont get any codes. I guess you can jump the c soloniod to put it in 50/50 mode.
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
On mine the AWD quit because the left rear axle had partially popped out of the rear differential. There's a circlip on the inboard end of the axle to hold it in place and somehow mine failed.
Did it make any suspiscious noises or give any clue before it happened?
I'm betting it's a messed up rear clutch drum. Fix it now before you blow the front differential!
There was no noise or clues, just lack of AWD. My mechanic friend noticed it purely by chance.
I still think my AWD is hit or miss. It could be that I'm used to a manual tranny and the 50/50 split, but it just seems like my car doesn't handle as good as it should. The snow tires helped out immensely, but I'm still left thirsting for more. I really need to hit the lottery so I can do my 6mt swap
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle 06 Hyundai Sonata GLS, 77K miles |
Don't do this unless you want your trans to die rather quickly and want sh**ty gas mileage...
you cant run the car at 50 50 at all times cause it will bind on every turn. Ask AWDinc for the parts you need. they got trannys out tha ying yang. Try to verify your problem first before you go buying parts. Talk with one of the Toms!
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click Last edited by SomethingElse; 05-02-2009 at 12:46 PM. |
Alright, I thought you were suggesting this as a way of having awd...
I'll have it checked for a popped axle
Have you checked for codes? If not, it would be very worthwhile to do so, both ECU and TCU. The above could indicate a speed sensor problem, depending on how the information is interpreted. The FWD light is not intended to indicate a diagnosed fault, and is an indication that this mode has been selected by fitting the fuse.
