#91
The final drive was 3.9 on the sti's from 04-06 starting in 07 they went to the 3.545
#92
you misunderstand Jman... Final drive is commonly misconstrued for the differential ratio... This is not the case.
The front diff on the 07 trans is probobly still a diff ratio of 3.90 much like the wrx... Also like the wrx it has a 1.1:1 step down ratio for the rear drive. This allows the use of a 3.545 differential... now multiply 3.545 by 1.1 and what do you get??? 3.9... thus the compatability of a 3.90 front diff and a 3.545 rear diff... Now these calcs won't be exact as they are rounded figures but you get what I mean... Anyway the purpose is to reduce the rotations the driveshaft sees in order to reduce u-joint wear and also allows for stronger bearings to be used in the U-joints. it also helps to keep vibrations from the driveshaft at high speeds to a minimum Tom |
#93
This also means MORE forces applied to the rear diff gears, so easier to shread the gears
#94
tom |
#95
I was just thinking that the SC-EG33 just "Might" put out a little more torque than a stock EG33.....but I could be wrong I suppose
#96
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
#97
the 07 does have wider 2,3 gears and I believe that 6 gear is too
#98
Tom |
#99
Just let my ex drive it... I'm sure she could break it
#100
I did 7 g tech runs last night (closed privately-owned road) The best run was a 12.66 @ 104.1mph and the worst was 12.98 @???mph. It is dead level and dead straight. I know it is just a G tech but it really makes me want to get out and get an official time now.
#101
Nice! So, when are the dyno runs?
-Bill
#102
Sweet......
#103
Uhmm hoping for next thursday...
#104
Well..... i have it. My '07 6 spd. I got to the kids house last night at about 8pm and left at about 6:05AM. Stuff that I got: 6 spd, rear end, 4 axles, starter, clutch, master cylinder, pedal box, steering wheel, shifter trim, driveshaft. Stuff that I am selling on ebay: front brembos, airbag sensors. All in all I think that for the stuff I am keeping it will work out to have cost me almost $2k even. Deal of a lifetime......
#105
PMing you
