Thread Tools | Rate Thread | Display Modes |
FS:AZ: '04 STi 6 Speed Transmission + R180 rear diff **PRICE REDUCED**
***SOLD***
Howdy Subaru Peoples! Up for sale is a 6 speed transmission (Tranny code: TY856WH4MA) from a USDM 2004 WRX STi with 30k miles on it(That's what I was told anyway). I no longer have a car to use it, so it is now for sale. All that comes with it is: 6 Speed Transmission (needs DCCD wiring harness. can be ordered from Subaru dealer for $50, Also needs input shaft seal replaced but I have one and will be included) Tranny mount and crossmember Shifter Input shaft seal Clutch master cylinder and slave cylinder with tubes and hoses R180 rear differential with dogbone rear mount 2 rear axles (one of the outer cv boots need to be replaced on one, and the threads(where the axle nut goes on) is buggered up a bit on the other one ) Flywheel, but no clutch (the friction disk got oil on it from the leaking input shaft seal) Left and right axle seals for front diff Plug for access point for shift fork pin New stud for rear diff (one is chewed up pretty bad) Stub shafts for front diff (These can be used to attach female front axles. This can be useful for swapping into '93-01 Imprezas, '90-04 Legacys and SVXi ) Pedal box (just brake and clutch, doesn't come with an accelerator pedal) Starter motor Brake master cylinder and booster Thanks for looking!
'95 SVX L AWD 99k(R.I.P ) 4.44s Bontrager Works RSB ECUTune V1.4 Custom Cat-back Last edited by ManYaik; 01-13-2017 at 05:30 PM. Reason: because reasons |
Re: FS:AZ: '04 STi 6 Speed Transmission + R180 rear diff + other parts
BUMP still for sale
'95 SVX L AWD 99k(R.I.P ) 4.44s Bontrager Works RSB ECUTune V1.4 Custom Cat-back |
BUMP Price Reduced
So in Layman's terms, what all else would be needed for a swap into my 92 SVX other than what you have listed?
A clutch, longer flywheel bolts, and a custom crossmember
***sold***
