Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 03-18-2017, 01:49 PM
socal1200r's Avatar
socal1200r socal1200r is offline
Direct bolt-on calipers
I've searched thru a bunch of these brake threads, and just so I haven't missed anything, there are NO upgraded calipers that will directly bolt onto the SVX, yes? I read one that said WRX calipers have the same bolt holes, but the SVX rotors are too thin and you'd have to get thicker rotors.
So again, there are currently NO calipers that are a direct, bolt-on replacement for the stock SVX calipers that won't require changes to anything else?
1997 Subaru SVX LSi
Honda Accord wheels 17x7.5, 235/45s, 5mm rear wheel spacers; "3.3" and "AWD" badges on front fenders; AMR radiator/fans; lowering springs, s/s brake lines, drilled rotors; Stebro exhaust with quad tips, mid-muffler removed; tinted windows.
Old 03-19-2017, 09:41 AM
92 SVX 92 SVX is offline
Re: Direct bolt-on calipers
correct there needs an adapter to bolt up any other caliper
Old 03-19-2017, 11:15 AM
There is a project over on SVXNATION And HISE-TECH to bring over the 4-pot calipers, designed for the JDM SVXs.
4pot front/ 2pot rear, plus larger rotors, designed for the OEM 16" wheels.
Old 03-19-2017, 03:05 PM
As far as I know the JDM SVX didn't use any other calipers, if so we could just put those on the usdm svx they didn't change any brake mount locations on any of the svx, it wouldn't make financial sense to do so. for such a limited number of cars, However that being said there is a plan underway for "cheap" 4 pot/2 pot to be made to fit
Old 03-19-2017, 06:24 PM
Originally Posted by 92 SVX View Post
As far as I know the JDM SVX didn't use any other calipers, if so we could just put those on the USDM SVXthey didn't change any brake mount locations on any of the SVX it wouldn't make financial sense to do so. for such a limited number of cars, However that being said there is a plan underway for "cheap" 4 pot/2 pot to be made to fit
Check with Jamie Price over on SVXNATION. This is the whole idea. The JDM 4 pots do fit. He can explain all the technical details to you. Send him a message.
The first sets of calipers are en-route from Japan. For those of you inquiring about the brake upgrade kits Unfortunately they are being shipped PAL which can take up to 14 weeks to get to Philly.
Old 03-19-2017, 08:29 PM
socal1200r's Avatar
That sounds all well and good, but right off the bat I wouldn't be interested in that, because the JDM calipers would have to come from Japan, and I'm sure they won't be cheap. What I'd be interested in is being able to take calipers off a WRX or something similar, and with minimal effort, bolt them right up to a stock SVX brake system. No bigger rotors, no changing hubs, etc. That, combined with s/s brake lines, should be a "Stage 1" brake upgrade. Simple, not very expensive, and something that won't require special tools or a lot of time.
1997 Subaru SVX LSi
