Headlight refinishing
I took apart my headlights and cleaned inside them over the weekend. Check out my locker under 'headlight refinish' for pics. Let me know if you want me to type out the process in detail.
-mike |
Very impressive. Yes, please give a step by step process on how to do this, and the supplies needed. TIA
. Earl .... ... .... ><SVX(*> Subaru Ambassador [COLOR=silver]1992 Tri Color L[/COLOR] ~45K (06/91) #2430 1992 Dark Teal LS-L ~184K (05/91) #0739 1992 Claret LS-L ~196K (05/91) #0831 1992 Pearl LS-L ~103K (06/91) #1680 1992 Pearl LS-L ~151K (06/91) #2229 1992 Dark Teal LS ~150K (07/91) #3098 (parts car) 1992 White LS-L ~139K (08/92) #6913 1993 25th AE ~98K (02/93) #164 1993 25th AE ~58K (02/93) #176 1993 25th AE ~107K (02/93) #215 1993 25th AE ~162K (02/93) #223 1994 Laguna Blue Pearl LSi ~124K (1/94) #2408 1994 Laguna Blue Pearl LSi ~144K (10/93) #1484 1994 Laguna Blue Pearl LSi ~68K (10/93) #1525 1994 Barcelona Red LSi ~46K (02/94) #2624 1994 Pearl LSi ~41K (12/93) #1961 1995 Bordeaux Pearl LSi ~70K (02/95) #855 1996 Polo Green LSi ~95K (03/96) #872 1997 Bordeaux Pearl LSi ~55K (08/96) #097 2003 Brilliant Red LS1 Convertible ~29K (04/03) #8951 1999 Magnetic Red LS1 Coupe ~33K (04/99) #6420 My Email | Old Locker | New Locker | Picture of 15 of the 19 |
Ok here we go.
What you need: Blue Magic Plastic Cleaner Blue Magic Metal Polish Terry Towls Powerful Heat Gun 10MM Socket Screw Driver Step by step. 1. Remove the headlights from your SVX. To do this, first remove the grill and the 2 corner lenses. there are then 2 10mm bolts holding the headlight in on each side of it. there is a total of 4 for each light. It will then pull right out. 2. Remove the metal clips that hold the clear lens part of the light to the back black plastic piece. 3. There is now some hard sealer around the joint that needs to be taken care of. Get yourself a good heat gun. You need to get it pretty hot. go around the joint with the heat gun. You will see it begin to melt the sealer. 4. It is best to have someone help you for this step. Have a friend pull the 2 pieces apart, while you continue to heat the areas with the heat gun. The light will get pretty hot, so it is best to wear gloves when handeling it. The clear lens part is very difficult to melt with the heat gun, but the black plastic portion gets very soft, very fast. Be careful with that. 5. Once the lens is seperated, clear the inside of any large objects. There was a lot of spider webs in mine. 6. Soak the lens in warm water. The lens will be hot from the heat gun, so it is best to use the warm water so that the temp change doesnt shock the plastic and cause it to crack. 7. Then, completely dry the lens. 8. Take the Blue Magic Plastic cleaner and apply a coat to the inside and outside of the lens. Wait for it to haze and buff it off by hand with a soft terry towl. Repeat this step till all the yellow is gone. 9. Apply the Blue magic metal polish to the inside and outside of the lens. Again, wait for it to haze, and buff it off by hand. Repeat this step a few times too. 10. Now, you will notice some buildup from the cleaner and polish has formed. Rins the lenses again, and use a Q tip or similar to remove the buildup. Then dry the lenses completelly. 11. Now, use the heat gun to melt the sealer down again, and press the lens back onto the rear black piece. 12. Hold the pieces together until the bonding material sets. 13. Then, replace the clips. 14. Put the light back on your SVX, and admire your ultra-clear headlight. YOU'RE DONE! |
I have photos of how Doug and I did that. I will post them sometime tonight.
Lwin
Lwin M. Maung (Member # 147) Current SVX: NONE Previous SVXes: 1994 LE Barcelona Red 107k 1992 LS-L Pearl White 143k 1994 LSi Bordeaux Pearl 220k 1992 LS-L Ebony Pearl 184k 1992 LS-L Liquid Silver 145k 1992 LS-L Liquid Silver 102k 1992 LS-L Ebony Pearl 123k Other current cars:2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
AWESOME!!!! That looks SOOOOO SHARP!!!!!! WOW!!!!!! I can hardly keep my hands off of my toolkit because I want to do it RIGHT NOW!!!!! that's so incredibly cool. Thanks for posting step-by-steps mike, otherwise I don't think I ever would have done it. I seriously cannot believe how good that looks. I do have a question though.. why do you use METAL polish on the outside of the lens? I can obviously understand using plastic polish on the inside.............but.......well i think you can see where i'm confused. Thanks in advance
-adam EDIT: ps.... could you pretty much do the same thing with the center grille???? Last edited by alacrity024; 05-20-2002 at 06:41 PM. |
You use the metal polish on the inside and outside of the lens... sorry if i didnt make that clear The metal polish is recommended on the back of the plastic cleaner for making the plastic shiney.
I would imagine you could do the same with the grill, but I didnt take a look at it. Good luck, and if you have any questions while you're doing it, gimme a call 717.917.2476 -Mike |
Alright, now I'm going to have to rent me a heat gun and an extra pair of hands! Any KC area owners want to spend this weekend working on some SVX improvement projects?
KuoH |
aredub.....
looks like me and you are going to have to get together and fix us some headlights. i will buy the supplies and do all the sanding. you get to take the stuff apart.
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!! "Too much fun to drive!" |
green95svx i did the exact same thing took the headlights all apart waxed and cleaned it 3 times before puting it, looked like crystal clear but,, after 3 months or so , it turned yellow again on me,, damm u headlights, LOL so i just wax the outside every few months it seems to keep them clear im going to buy new set here soon, if your process last throught the time i would be verry impressed,, and i hope that it does
p.s do they sell headlight covers for svx,,like GTO covers |
No, noone makes headlight covers for the svx. -Mike |
i hate headlight covers, but for the svx.....
i would almost consider it. my headlights are in horrible condition.
I am going to put a layer of that stuff on my headlight. Lwin
That looks pretty good. Maybe I should get my ligts out and take car of th inside too. I just wet sanded them over the weekend and then buffed them a few times. Whe I stepped back and looked at them with the lights on, I almost wet myself. What a way to get all the highway pits out. IT LOOKS SO GOOD.
Mike W 92 SVX LSL, Ebony Mica/Grey leather, K&N Cone, Pioneer Dehp-7300 premier, White Guages, Radar detector, Volfenhag VDX 12's, Memphis ST1000D digital amp, CompuSTAR 2000AS 2 way paging alarm with visual confirmation, and auto start. Cell Holder, Xenon (Ebay) bulbs in highs lows and fogs, Wire loom in engine bay, and a kitchen sink complete with soap dispensor and soap scum. |
SVX Headlight saver part number
Subaruparts.com has the pre-cut 3M plastic headlight savers for the 92-97 SVX. They go for $27.94 plus shipping.
Go to http://www.subaruparts.com/catalog/?section=176 and scroll down the page. Part #10800
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member 2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
nice svxceess
i wonder if u can use that translucent paint like smoke color or something to hid the yellow lights or i wonder if it will stop the headlights from turning,,
Thread Tools | |
Display Modes | |
