Old 04-05-2005, 06:21 AM
poweredx2 poweredx2 is offline
Well my front springs have been heated to lower the front,which help ga ve me that raked stance and a better launch.If I would put half the effort in some good coilovers I could run better on street tires,maybe later but not now.
Old 04-05-2005, 06:22 AM
immortal_suby's Avatar
Thread Killah
Holy carp Walter, that thing is getting very fast.
If you want a cheap and sticky tire check out the Falken Azenis Sport. They do not last very long but they are cheap and ultra sticky and street legal.
Locker Link
2015 BRZ Limited 6MT
Old 04-05-2005, 06:26 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Sounds like you've done what you can afford to get better traction. Upgrade to stickier rubber like the Falken Azenis Sport that Matt recommended and you should be all set...
-Chike
2006 Steel Gray WRX TR (sold)
Old 04-05-2005, 04:37 PM
svxsubaru1's Avatar
Originally Posted by Chiketkd
Btw, are you still running a stock suspension Walter? If not, you might want to look into stiffer sport srings front & rear which should lower the front by 1.5-2". This should reduce the amount of rearward lean in the car when you mash the throttle - keeping the front wheels planted.
-Chike
That is damn quick 109MPH whoo i wish my car could do that in the 1/4.
Aculley the largest benifit from lower the car would be a reduction in weight transfer from front to rear, from the lower center of graviety, not becasue of less lean. If you do the caculation it would be only be about 5-10 pounds transfred due to the body lean, but it would be in the hundreds pounds of transfered weight from the center of graviety. Thats why alot of RWD cars have there ass in the air, to increase weight transfer, to the rear.
