Old 03-27-2005, 10:25 AM
jb21585's Avatar
jb21585 jb21585 is offline
Switch for my AWD
Has anyone made a switch to turn awd on and off, if so please reply. I may have thought of a way to do it but i need some support.
Old 03-27-2005, 04:04 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Any particular reason for doing so? You sure you want to risk tranny damage? (AWD not designed to be driven in FWD, the fuse is a service feature, not a driver option.)
Old 03-27-2005, 05:20 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Beav is right. I wouldn't be messing with that fuse unless you need to troubleshoot.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 03-27-2005, 07:31 PM
jb21585's Avatar
the reason is for more power when i need it and for better fuel economy. I figure i could wire the switch in by rerouting the wire going out from the fuse to the switch.
Old 03-27-2005, 07:53 PM
n00b on demand's Avatar
Not a good idea. Your going to ruin the tranny. I wouldn't do it if i was you. If gas mileage is really that much of prob then sell the car. The car is probbaly much better to drive with AWD anyway.
Old 03-27-2005, 08:41 PM
Rotorflyr's Avatar
You won't really get more power or better gas mileage by doing that. If your looking to improve acceleration on the low end go with an ECU Tune stage1 chip which will also allow you to run regular gas, while not necessarily improving mileage, will be cheaper to fill the tank.
2006 B9 Tribeca
Old 03-27-2005, 09:50 PM
yea getting the chip is actually a good idea. I think the price is around 210ish?
Old 03-27-2005, 09:54 PM
Rotorflyr's Avatar
$219 + shipping
ECUtune
2006 B9 Tribeca
Old 03-28-2005, 02:51 AM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
Why do people think that running with the all wheel drive disabled will save fuel? Whether the rear wheels are engaged or not, all the parts still have to turn. Is there any explanation, no matter how contrived, for how this could possibly save fuel?
UberLocker
Old 03-28-2005, 05:13 PM
Yes UberRoo, we have seen this put up as a way of saving gas before.
It does not matter which way you drive the back wheels, they still have to be driven by the motor.
Either through the clutch, drive line, rear diff to the wheels. Or through the front wheels, through the road, to the back wheels, to the diff, drive line, to the back of the clutch.
The motor still has to do it.
Old 03-28-2005, 09:34 PM
Beav's Avatar
Not as old as Randy
It may come from those that don't understand the difference between AWD and the 4WD trucks of years gone by. The trucks with 4WD were biased to drive the front wheels slightly faster (e.g. a front axle ratio of 4.09 and rear axle ratio of 4.11) in order for the front wheels to pull the vehicle in the direction they were steered when in really sloppy stuff. The downside was the binding up encountered when driving on solid surfaces which would use more fuel/power to overcome, not to mention driveline damage. Plus, many of them had some form of axle or hub disconnects that would allow the rest of the powertrain sit idle and not suck up power by being forced to revolve by road force.
Old 03-29-2005, 06:04 AM
svx_commuter's Avatar
Beav, I always learn new information from you. I had no idea that is how the old 4WD vechicles were made. I thought the ratio was the same front and back. Now I know why people used to burn up the drivetrain or tires if they drove in 4WD on dry pavement.
I have heard that driving in the FWD mode for long periods of time can cause the transfer solenoid to gum up and freeze. Then you no longer have AWD when the SVX put back into AWD.
I think disconnecting the RWD does save gas but only if you drive mostly on roads with lots of turns. That’s the only time the front end of the transfer clutches wants to run at different speed than the back end of the transfer clutches. The power consumption is dependent on the transfer pressure level and the tightness of the turn.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 03-29-2005, 06:32 AM
Roo Roo is offline
Send a message via AIM to Roo Send a message via Yahoo to Roo
Trade??
I'd be happy to trade you my FWD SVX for an AWD SVX.
Better gas mileage ALL the time...
'92 SVX LS-L
Project Car for Open Road Racing
Old 03-29-2005, 02:56 PM
Beav's Avatar
Not as old as Randy
The only time there is any power difference between front and rear is when there is a lack of traction at one end. It doesn't make much difference what the duty cycle is. Look at it this way - the solenoid on/off time is measured in milliseconds, how much difference in mpg will it make if the front receives power a few more ms than the rear? Whichever end is getting the ponies is going to have to push/pull the other end around.
Personally I think most of the discussion re: torque split is ... well, I'll just stop here. I think a better expense of energy would be to put together a driver's school weekend, at a discounted rate, for the members. That would yield far more positive results.
Old 04-10-2005, 11:12 PM
WGJ WGJ is offline
Drivers School!!!
Yeah what a great idea.
WGJ
