Old 12-14-2004, 06:52 PM
Imprezzed's Avatar
Imprezzed Imprezzed is offline
Some Toolbox rolled it!
Send a message via Yahoo to Imprezzed
Vent Problem
Okay this one is weird. Windows were getting foggy, so I turned on the Defrost and set the fan to high. It went for about 5 seconds, and quit. I Switched it back to low, then back to high...no dice, but I hear a weird clicking noise coming from the passenger's side every time I change the fan setting. It's only one single click when I change the setting.
Any ideas?
1992 SVX LS-L Claret - RIP.
Old 12-14-2004, 07:39 PM
RobSVX
sounds like a Relay is bad.
Old 12-14-2004, 10:00 PM
Imprezzed's Avatar
Where would I look to fix the problem? Any help?
Much appreciated.
Old 12-15-2004, 05:29 PM
Imprezzed's Avatar
Anyone?? I need help with this, things are getting cold and defrost is a must!
Old 12-15-2004, 06:35 PM
Old Fogey
Here Goes!
Imprezzed, The FSM shows a self diagnostic mode to be used with the system in Section 4-7 but it appears a Select Monitor may be required to pull the codes. Relay and fuse info is also shown, but obviously I couldn't be sure the USDM and Canadian models are the same.
I could scan the pertinant pages and e-mail them to you, but you may be better off trying to get the info from a Canadian-model owner.
There's a D: Blower motor speed does not change" Diagnostic step indicating possible auto amplifier, fan control amplifier or HI relay(BM5) problem. The HI relay, blower and amps all appear to be behind the glovebox. This section of the manual is 139 pages. Any help??
Glenn
Old 12-15-2004, 09:06 PM
lee lee is offline
download the section from Reaper's ftp site:
http://reaper450128.homeftp.net/pdfs..._AUOTMATIC.PDF
run the diagnostics, then look at the fan section and start testing. I doubt any of us have enough info to point you to the one thing without more tests.
Old 12-15-2004, 11:24 PM
Old Fogey
reaper recommends accessing the files here for faster response and to free up his line:
http://seccs.org/tech/manuals/1992_SVX/index.html
Glenn
