Old 12-03-2004, 05:55 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Dilemma...
I have a 1994 red SVXlsi and it is in great condition. Although it has 160,000 miles, the body is near perfect except for the usually very few side dings. The tires are like new, it has new brakes, rotors, and bearings. The interior is near perfect as well and the car has been driving perfectly until two weeks ago. I started getting slippage (flaring) in either third or fourth gear. The question is...do I spend the money for a new transmission and then have a great car (albeit with 160k and not knowing what wiull go wrong next) or do I try to get whatever I can on ebay? What is it worth? I figure about $2500 for a transmission. If I got $1500 on ebay and saved $2500 I might be better off. HELP!! I just don't know what to do.
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 12-03-2004, 06:31 AM
dcarrb dcarrb is offline
What you have is a known commodity. What you might buy is a big question mark. If you really like your SVX and can see yourself keeping it for several more years, then you should.
dcb
Old 12-03-2004, 09:04 AM
drivemusicnow's Avatar
Poor College Racer
Re: Dilemma...
How much is your SVX worth to you?
If it was me, I'd keep it(depending on my financial status at the time) if you think about it, if you sell it for 1500, and put the 2500 with it... what car for $4000 would offer you anything close to what the SVX does.??? as far and wide as I have looked, for what the SVX is, there are NO other "alternatives" as reasonably priced...
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 12-03-2004, 10:04 AM
Before you do anything, first adjust the TPS to .50 volts.
Adjust the band, or have it adjusted for you.
Change your transmission fluid and filter.
DO NOT HAVE IT POWER FLUSHED!
That being said, Hmmmm, we don't have a red one .
Is it Brilliant Red or Barcelona Red?
The paint code is on the aluminum plate by the drivers shock tower under the hood.
Don't tell Di.
Old 12-03-2004, 03:18 PM
Thanks for the replies so far. I really appreciate the advice. I am almost positive it is Barcelona Red. I will check. I'll ask the transmission shop to adjust the TPS and Band (brake band??) and change the fluid and filter and see what happens. My guess is once they get the car in the shop, they are going to want to sell a transmission job and will tell me that the things you recommended didn't work.
Michael
Two-owner:169K
2008 Toyota Prius
Old 12-03-2004, 03:40 PM
Poor College Racer
just act like you know more than them, and tell them, do this, this this... and then ask for a test drive when its all done
Greg
Old 12-03-2004, 04:12 PM
The Jersy Shore Meet is coming up on the 18th, I'm sure someone going there can adjust the TPS or adjust the brake band.
Is that a far drive for you?
If it is slipping you don't want to take a long drive and burn it up. Maybe someone in your area can recomend a trustworthy shop?
Old 12-03-2004, 06:28 PM
Wahat is the exact location of the jersey shore meet?
Michael
Two-owner:169K
2008 Toyota Prius
Old 12-03-2004, 07:13 PM
Ciscokid
Hey files.....can you elaborate on that please?? By power flushing do you mean what they do at jiffy lube and dealerships now where they suck it all out and replace it with clean fluids??
I thought that was the best way to get all the fluid changed and I was going to have it done soon.
Old 12-03-2004, 08:29 PM
Jersey Shore MeetII
This will be the seond time I have held this meet. We will be meeting at a public lot as you first get on Long Beach Island. once we have established ourselves, we will take a ride over to our local Applebees where we can get some grub and chat. I know it will be kinda cold so bring some clothes to maych the heat. Anyway It is right off Rt 72 In Ship Bottom NJ 08008. It is exit 63 off the Garden State Parkway. For anyone comming from the west contact me for directions rt70,539,or 38, or any other route you would be taking, i can walk you through it best I can. Come on people and turn out for this SVX meet.
1.Tomssvx
Old 12-03-2004, 08:46 PM
Yes, thats what I meant, and "on paper" its a great idea, but...
It is my experience, and that of others in the automotive repair fields, that unless a car has less than 20,000 miles since new, or a rebuild, or the last power flush, it could wash out any fibers/sludge/varnish/debris that are keeping the seals/O-rings from failing.
There was recently a thread reguarding this, and the general agreement was that the Jiffy Lube process usually ended in failure. BTW, they make you sign a waver to say, when/if your trans fails, its not their fault Tom
Old 12-04-2004, 06:05 AM
Hi guys!
Is there anyone going to the Jersey Shore meet that could adjust my TPS and brake band on the trans?? Thanks.
Michael
Two-owner:169K
2008 Toyota Prius
Old 12-08-2004, 11:41 AM
Just a follow-up. I had my shop open the transmission pan and it was full of metal and the third gear was gone. I am going to be stuck for a transmission job and I guess I will be keeping the SVX for a while.
Michael
Two-owner:169K
2008 Toyota Prius
Old 12-08-2004, 12:45 PM
Mr. Pockets's Avatar
Moderator
While I agree that this does seem to be the case, I want a better explanation why flushing is a bad idea. If done properly (and I don't actually know whether or not it can be done incorrectly), a flush shouldn't put any more strain on the transmission than normal operation. Why would new fluid dislodge the debris that's keeping your feeble transmission operating? And if you have debris in your transmission, it came from somewhere, right? Not good.
My original transmission stopped shifting at 133k miles. Seemed like a total loss of hydraulic pressure. I had it flushed by a dealer, per their recommendation, and it worked fine.
For a week.
I don't blame the flush - I blame the fact that I had a blockage, caused by clutch debris. That debris lowered the line pressure, causing the clutches to slip and damaging them further.
Anyway, I agree, we have seen more than a few failures shortly after flushes. But I want a more in-depth study of why this happens before I say that replacing your fluid with a flush is a bad idea.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
