Old 11-30-2004, 04:41 AM
Sonar's Avatar
Sonar Sonar is offline
...And for those interested people....
Mean Effective Pressure (bar or kPa)
– power per unit displacement and stroke
– e.g. mep = Pn*1000/(VN)
  • mep in kPa
  • P in kW
  • n=1 for 2 stroke, n=2 for 4 stroke
  • V = engine displacement in Liters
  • N = engine speed in rps
...or read the lots here
/Sonny
Internal name: "SuperSonic"
-92 ebony black with 170k KM
*** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. ***
Old 11-30-2004, 07:06 AM
red95svx
Re: Interesting EG33 output comparison...
Originally posted by Chiketkd
Another observation is that the hp and tq values are almost identical on the SVX
-Chike
Apparently Subaru likes making engines with similar torque / HP ratings. Seems like quite a few Subarus have engines like that.
Old 11-30-2004, 07:26 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally posted by mbtoloczko
MEP is found from:
BHP/(rpm*displ)
rpm is in krpm (rpm/1000)
displ is in liters
MEP is a better way to compare the efficiency of different motors because it takes into account the rpms the motor is turning at peak HP. Its important to take rpm into consideration because greater rpm is an easy to create more power (assuming that some amount of torque can be produced).
Here are the results
car-------------disp (cc)----bhp----rpm at peak HP----MEP
300zx----------2960-------222----6400--------------11.72
Supra----------2997-------220-----6000-------------12.23
3000GT SL---2972--------222-----6000-------------12.45
SVX------------3317-------230-----5400--------------12.84
When taking into acct rpm, the SVX motor takes the win in efficiency.
It would be interesting to see what the SVX motor would crank out with longer duration cams, higher lift, and appropriately tuned intake and exhaust. If the MEP of 12.84 could be maintained but peak HP moved to 6500 rpm, the motor would be cranking out 275 HP.
Nice!
That's a very impressive MEP for the EG33. 275hp definitely seems like an attainable figure if those changes were made to the engine... DAMN!
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-30-2004, 07:30 AM
Chiketkd's Avatar
Re: Re: Interesting EG33 output comparison...
Very true Dave. Doesn't the EJ22 make like 135hp and almost that exact figure in torque? Also the USDM STI makes 300hp and 300lb-ft.
-Chike
Old 11-30-2004, 07:31 AM
Chiketkd's Avatar
Very good read Sonny. Started reading through the document, but need to bookmark it for later...
-Chike
Old 11-30-2004, 08:31 AM
red95svx
Re: Re: Re: Interesting EG33 output comparison...
-Chike
Yep and the 2.5 L is about 165 hp and similar torque, and even the 2.0 turbo has hp and torque ratings that are close.
Old 11-30-2004, 09:31 AM
Sonar's Avatar
It seems to be more correct to use the BMEP in our findings because
... the MEP not BMEP includes more than the average pressure on top of the piston during the power stroke. It's an average involving the measurement of cylinder pressure on all four of the strokes, and anything done to change the pressure in one or more of the strokes will affect the MEP with an increase or a decrease depending on what is done.
The BMEP is a hypothetical MEP determined by using known brake horsepower or brake torque.
taken from here
..and even more here
makes sense.....or... ...yeeh...whatever....
/Sonny
Old 11-30-2004, 09:45 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Originally posted by THAWA
you realize that an auto is not slower than a manual right?
The REAL Legacy turbo (i.e. 91-94) posted faster auto times than manual times. I'm sure the crappy Mazda wanna be they sell now doesn't as it has more turbo lag than a turbo prop plane .
Old 11-30-2004, 01:04 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
After reading all the posts in this thread I suddenly realized that I haven't been trying to make my car faster, I've really been trying to make it more efficient!
-Bill (dyno on the 15th.....dyno on the 15th!!!)
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-30-2004, 04:00 PM
drivemusicnow's Avatar
Poor College Racer
Here's the deal - an auto trans is almost identical to a manual except for the torque converter! <snip>
-Chike
^is not true... autos and manuals are completley different, go onto www.howstuffworks.com for a halfway decent explanation of each.
For better/more fun explanation... go to a junkyard, buy one of each, and tear them apart and try to rebuild them
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 11-30-2004, 04:17 PM
Torque converters, according to Chike.
Yes that was a pretty vague description of how a torque converter works. The missing component is the Torus or Stator. This is the bit that produces the torque multiplication.
I'll write something on them soon.
Old 11-30-2004, 05:03 PM
thundering02's Avatar
Giong back to the beaters...
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 11-30-2004, 06:01 PM
SVXelerator SVXelerator is offline
Frequent User
SVXRide,
Where are you going to dyno your car? Who's going to have the higher HP - you or Mr. Chike?
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$
Old 11-30-2004, 06:24 PM
benebob's Avatar
Originally posted by SVXelerator
SVXRide,
Here's my bet!
SVXride will have a lower hp but a better curve and higher torque
Chike will have the number.
Do I have any takers? Why must you do such fun things after my SVX is put away for the winter???
Old 11-30-2004, 07:12 PM
Chiketkd's Avatar
Originally posted by benebob
Here's my bet!
Thanks for the vote of confidence!
Personally though, I think Bill will have higher hp and torque numbers as he now has the ECUTune Stage 1 installed in his car. That chip is the main difference between his stock '92 and my stock '96 (my 4.11 gears won't affect my dyno numbers as gearing is factored in).
-Chike
P.S. My prediction is that Bill makes a hair over 170hp and a similar number in torque, while I'll be somewhere in the mid 160's...
