Old 05-27-2002, 09:48 PM
jsvxstyle jsvxstyle is offline
MINEZ BETTER
funky smell
when i turn on the a/c then turn it off after a while. this smell come out of the vent, and haunts me. is there a cure for this problem
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon
Old 05-28-2002, 03:25 PM
gcookaustin
It might be mold or something in there. On a hot day turn the heat on as high as it will go (econ) and leave it for an hour or two. That's what someone suggested..
Old 05-28-2002, 09:04 PM
Invisible avatar
Talking
Yeah, you've got dead ghosts in there, alright. I'd try some spirits of turpentine sprayed into the vents.
Works for me.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 05-29-2002, 06:48 AM
kuoh kuoh is offline
I don't know about turpentine, but a can (or two) of lysol in the intake vents helped to get rid of the wet sock smell in my AC. I think I alternated between high heat, vent, and cold for about 10-15 minutes each. The lysol smell will persist for weeks if not months, so choose your fragrance carefully.
KuoH
Old 05-29-2002, 04:56 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
If you can get underneath your car look for the a/c drain on the right side floorboard near the bellhousing. Make sure it is clear and unobstructed. Usually the drain collects debris (leaves, etc.) and doesn't drain properly. Sometimes the condensate from the a/c collects so much that it leaks from the a/c case and soaks the passenger carpet and pad - another place for mold and mildew to flourish. Look up under the glove box and pull the carpet towards you a tad to see if the backside is damp. If so you'll need to pull it up and air it out, maybe use a fan and some mildew killer. Make sure you find the source of the problem so it doesn't repeat itself.
Old 05-29-2002, 07:14 PM
oab_au oab_au is offline
Floor board?
[QUOTE]Originally posted by Beav
[B]If you can get underneath your car look for the a/c drain on the right side floorboard near the bellhousing.
A Beav Thats a bit dating, I have not heard them called that since the 30s when there were boards.
One Arm Bloke.
Tell it like it is!
Old 05-29-2002, 08:13 PM
Invisible avatar
Question Re: Floor board?
[QUOTE]Originally posted by oab_au
[B]
I give up, Harvey, what do Oz people call "floorboards", which is what we yanks still call the piece of sheet metal that keeps your feet from dragging on the road.
Ron.
'01 Miata SE - 79K
Old 05-29-2002, 08:26 PM
Re: Re: Floor board?
Ron.
How about the "floor!" Floorboards are wood aint day?
One Arm Bloke.
Tell it like it is!
Old 05-29-2002, 09:00 PM
Beav's Avatar
Not as old as Randy
Uhh....kinda. Have you seen what's under the RF carpet pf a 928? A hunk of marine plywood covering the most catastrophic fuse and relay center you've ever seen in a car.
Actually 'floorboard' is a colloquial word here, entirely interchangeable with 'floor'. And I still say 'groovy' once in a while...
Old 05-29-2002, 09:21 PM
Invisible avatar
Wink Re: Re: Re: Floor board?
OK - Explain bonnets & boots, & why in the Lawd's name would any country put the gear shift in the LEFT hand of a driver when 90% of the population is right handed?
Hrummpf. Ron.
'01 Miata SE - 79K
Old 05-30-2002, 12:59 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
autozone
sells this small can of Ozium stuff you can spray under the dash
thru the a/c vents and cores.......helps eliminate odors too.....
and like they mentioned earlier......check the drain that exits under the car...dg
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 05-30-2002, 05:59 PM
Re: Re: Re: Re: Floor board?
Hrummpf. Ron.
I remember even the old US police Indian motorcycle had a left hand throttle, so the cop could shoot with the right hand.
In Oz more important things are done with the right hand. like giving the fingers to other drivers. In my case being completely left handed I have to open the roof and use the digits that way, otherwise I find the left hand shift very handy. , don't know about the other 90%. Just as well I live in Australia.
lefthanded as usual.
One Arm Bloke.
Tell it like it is!
