#121
Re: EM Solution
Alright... Mark me down for one probably next spring or so....
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#122
Re: EM Solution
Are you running FI? 6 speed, right? That sort of thing. I thought you ditched the supercharger, so I was curious what you're running now.
If your build is in another thread, let me know and I'll go look there. Or maybe I'll just go look anyway.
1992 LSL Pearlie: 108k, 15min/$15 mod, Alternator wiring "upgrade," Power Mode switch, K&N drop-in, 4500k 35w low-beam HIDs, 3000k 35w fog HIDs, lots more planned (pending funds, of course)- 4.44 5spd being at the top of the list. "We laugh at honour and are shocked to find traitors in our midst." -C.S. Lewis |
#123
Re: EM Solution
He was running the hydra on a stock motor at first, then threw the stage 3 back on and tweaked it for that 12.99 run.
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
#124
Re: EM Solution
-Bill
#125
Re: EM Solution
I hope Tom does get some really good numbers. He has all winter to play with settings to dial it in.
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
#126
Re: EM Solution
Re: Hydra Nemesis
It is now available for OBDI automatics as well.
I checked the inputs from the ECU and could only find 2. 1. Engine speed (taken car of) 2. Atmospheric pressure (built into stock ECU... gonna have to deal with a code) and then there is the torque control line which I may or may not work on in the future. You will lose the torque control, which anyone buying the Hydra probably does not want. If anyone in the future wants to hire me to write a map and program the ECU to use it... I would be willing. Tom P.S. I will be working on getting OBDII harnesses made so all SVXi will be able to use this |
#128
Re: Hydra Nemesis
YT,
Did you get my email response to your email today? -Bill
#129
Re: Hydra Nemesis
Yes bill, got it and made my decision...
For other viewers... OBDII comming next week Tom |
#130
Obdii...
...or today I spent last night wiring a jumper harness to jump from the OBDII ECU connector to male OBDI connectors. Took about 4-5hrs total.
I then plugged the OBDI male connectors into my Nemesis harness out of my car. Plugged the whole bit into Its Just Eric's 96... Runs like a champ. I still need to pull the codes off the TCU to see what is acting up... I am going to imagine the comm port for the ECU and torque control, neither of which hinder the transmission's ability to operate normally... SO... I will let you know what they are but the car does run and drive well with the Nemesis on an OBDII platform. Tom |
#131
Re: Hydra Nemesis
I might take one for my pearlie at some point soon....
#132
Re: Hydra Nemesis
Ok, OBDII TCU codes are for the MAF(not functional) and torque control signal.
I am tinkering with the idea of selling TCU's without these things if people cannot stand to see the Power light or ATF temp light flash 16 times on start-up. Otherwise... Its good to go!! Tom |
#133
Re: Hydra Nemesis
Tom, pardon me not willing to take the time to re-read everything here, but what are the inputs for the system again? Is it a MAP... I mean, this eliminates the MAF, right?
Sorry, probably a stupid question.
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
#134
Re: Hydra Nemesis
Yes. The Nemesis has an on-board MAP sensor and it conjunction with an external IAT, eliminates the need for the MAF.
Tom Last edited by TomsSVX; 12-25-2008 at 10:30 PM. |
#135
Re: Hydra Nemesis
You've got me thinking about a TT EG33! |
