Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Engine Management
Old 02-01-2009, 12:59 AM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
Re: Hydra Nemesis
What error codes would you possibly need to check? You can just open up your laptop, plug in, and look at every value of every sensor directly if you'd like.
Why count flashing cels to see if the O2 sensor is out, just go see the zero for yourself!
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
Old 02-01-2009, 07:04 AM
Re: Hydra Nemesis
+1......
Old 02-01-2009, 07:29 AM
longassname's Avatar
Just some dude.
Re: Hydra Nemesis
Actually I entered dyno information for a stock svx into a shift calculator and came up with the ideal shift points for 1/4 mile drag racing at 7200 rpm from 1st to 2nd and 6800 from 2nd to 3rd. It seems worth doing. I also happen to like my shift maps a lot better. I posted the code for the most significant shift map changes in Phil's thread so anyone who wants to do this is welcome to use it. Changing the full throttle rpm limits for each gear is easy. Chipping the tcu is very worth doing.
Originally Posted by TomsSVX View Post
The redline is fully adjustable. Honestly with the stock engine there is no need to spin it any higher as you run out of power before you run out of revs.
You only need a chip for the TCU if you want higher shift points. I do not offer this right now but you may be able to talk to B3hla about how to do it yourself or maybe have him do it for you.
Old 02-01-2009, 07:31 AM
Just some dude.
Re: Hydra Nemesis
ps, please don't anyone take that as an indication that I'm saying your engine will hold together at those rpms. I've had a stock svx blow a rod bearing on a dyno below 7000 rpm's. There's no way to know what oil clearances a stock engine has so it's kind of the luck of the draw.
Old 02-01-2009, 09:34 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Hydra Nemesis
Originally Posted by longassname View Post
... so it's kind of the luck of the draw.
As is much of life
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-27-2009, 02:17 PM
Banned
Re: Hydra Nemesis
Tom id like to get an order placed for the hydra with base maps to be received in utah the second week of may
Old 02-27-2009, 06:44 PM
Re: Hydra Nemesis
Johnny, call me or shoot me an email and we can get the ball rolling
Tom@allwelldrive.net or (609) 276 7279
Old 02-27-2009, 08:00 PM
SVXRide's Avatar
Re: Hydra Nemesis
YT,
Did you get my PM with the flared tubing info?
-Bill
Old 02-27-2009, 08:04 PM
Re: Hydra Nemesis
Yes Bill, I will be calling them as soon as my hydro-jet flanges come in hopefully tomorrow
Old 02-27-2009, 09:39 PM
SVXRide's Avatar
Re: Hydra Nemesis
Nice! Hey, do you happen to have the dimensions on our lateral links (length - bolt through hole to bolt through hole) and width of end blocks)?
Thanks.
-Bill
Old 02-27-2009, 10:05 PM
Re: Hydra Nemesis
ya know they make these things called phones
Old 02-28-2009, 10:14 AM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Re: Hydra Nemesis
Header flanges Tom? If so, PM me a price and details (thickness, mat'l). Thanks.
Bob Légère
EG33 Impreza tweaks
Old 02-28-2009, 10:23 AM
Re: Hydra Nemesis
Yea, 3/8" thick mild using the manifold gasket as a template. Reduced the ID by .0020" to get good grip over the gaskets. I can have them made in SS too if you would rather... Let me know. I am having half a dozen made which is gonna cost me around $350. I had more than I need made in case anybody else needed them. More importantly I am having all the flanges for my intake made. TB, Runners, and blower flanges. I am having two sets made just in case someone else w/ a stage 3 wants a manifold that flows well. They will be constructed of thin mild and ceramic coated.
Old 03-01-2009, 08:28 PM
Banned
Re: Hydra Nemesis
Alrighty, I'll give ya a ring sometime this week, when I get a chance.
Old 03-02-2009, 06:44 AM
Banned
Re: Hydra Nemesis
ok so I'm confused... do I need a tcu?? or do I have one sitting there hooked up for no reason? or is it only not needed when I start running the hydra?
Also, tom is it possible to push the rev limiter slightly to get the better power band area like lan was talking about?
