Old 01-23-2008, 06:02 PM
Originally Posted by ricktheseabee View Post
Read it, and decided to call him personally and inquire.
Talked with him for a little while and he sounded sincere.
He agreed that trus would have to be built for me to do that much business.
I am sending him the money for one part to be overnighted and depending how that goes we will build on it or stop further business.
Im not asking anyone here to agree with me, i am just tought that deep down everyone is a good person if you let them. Its a cheap part, im not too woried if it goes sour. Yall will know the outcome in less than 48 hrs.
Rick
Admirable to continue on with it, hopefully it doesn't end up biting you.
Old 01-26-2008, 03:56 PM
ricktheseabee's Avatar
ricktheseabee ricktheseabee is offline
Got The Svx Running After Sitting For Two Years, Now What?
Got the cam sensor I ordered from Dans_Carpars (HE CAME THROUGH WITH NEXT DAY DELIVERY) and installed it and finally started up the SVX after over TWO YEARS!!!!
Is there anything I should do before I put it in gear and attempt to move it after its been sitting for so long?????
Now that its started, I will not engage the transmission till I get some answers from yall, anyone reading this, feel free to give your thoughts.
I want to be extra carefull cause I know its tempermental like that.
Rick
92 SVX-LS, BLACK, 189k Fiona
Old 01-26-2008, 04:57 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
No advice to give but that has got to be one great feeling. Congrats.
Gene
Gene and Ben
Old 01-26-2008, 09:48 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Good to hear of the resurrection!
I'd make sure there is pressure in the braking system before putting it into gear, and/or have the emergency brake ready (or plenty of room )
If you have AT fluid on the front of your engine, it is most likely from the PS pump as someone else mentioned
Look here for the fix:
http://www.subaru-svx.net/photos/user.php?How-To|14247
Myself, I'd let it idle a good 15-20 mins, then look for any serious leaking before taking it anywhere.
Also, I'd check the level and replace the coolant soon. Same for the brake fluid, front and rear diff. oil too.
Then..enjoy your test drive
Rick
'20 Honda Ridgeline
http://www.x35design.com
Old 01-26-2008, 10:49 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
You're still gonna want to replace those cheapy sparkplugs.
Dustin
-Dustin
Old 01-29-2008, 06:09 PM
Ok, brake presure, rear, front dif, trans fluid, oil top off, replace cheapie sparks, let idle for 15 to make sure no other oil, replace ps pump.
Ill have plenty of time to gather a list fron yall to ensure every precaution is taken cause im here in Georgia for another week and a half.
More ideas are welcome and will be noted.
Many thanks to all,
Rick
Old 01-29-2008, 08:52 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Rick,
Just so I've got it right, you ended up replacing both the cam sensor (driver's side) and one of the crank sensors (behind the alternator)?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
