'94 FWD transmission non conversion swap questions
Hi,
I've read a lot of stuff on this forum regarding SVX tranny swaps, but most seems to deal with MT conversions, or FWD to AWD conversions. There are a lot of posts out there dealing with AWD transmission replacements, but not much on FWD swaps, so I have started this post to try and get some expert opinions on issues related to doing a FWD to FWD automatic tranny swap from a non-svx Subaru donor vehicle. Background on my situation: I've got a '94 FWD SVX with a blown automatic tranny. Getting the transmission rebuilt is very expensive, so I am looking to get a good used one. However, as you all know, the used FWD SVX tranny's are rare and go for a premium. I am not interested in doing a FWD to AWD conversion, nor am I interested in doing an AT to MT conversion. I just want to stick with a FWD 4EAT 4spd automatic. Here are some questions that would be very helpful to get addressed by you knowledgable folks:
Thanks for your opinions and thoughts! Philip |
Re: '94 FWD transmission non conversion swap questions
I will attempt to answer your questions;
1. yes,yes,yes 2. If you can find a 3.9 FWD go for it.I can't speak for how much of a difference you will see from 3.7 to 3.9 but I can't imagine its huge. 3. Not sure, I know early imprezas had FWD 4. No TCU change is needed, keep the FWD with FWD and you will be fine. 5. No it should be fine. there is a gear mechanism in the transmissions that give speed based on rotation. You do not need worry about that. Although I think higher ratio might put it off a slight bit (I am not 100% but nothing to be worried about). 6. Not that you can, but avoid Phase II 4EATs (not compatible nor come FWD) 7. Not sure of any in the US anyways. I believe the loyales and etc were all 4wd that came turbo. 8.No, you can pull the old stubs if needed and put them in the new trans. IIRC they should all be male and correct spline count. 9. No should all plug and play 10. No but you should change it when you put it in to be sure. 11. All the shift kits do is raise the pressure, I don't think anyone has confirmed that it helps in the long run. 12. Front drivers side wheel well (in front of the tire). If you live in a climate that gets cold you might run into problems with the tempature not reaching the correct operating temp. If so you will have the TC unlock at highway speeds if I recall correctly. I lived in central NC and had a cooler on my FWD. I don't recall running into this problem but it wasn't usually below freezing. 13. You can do either but if you do it here the search will pick up on everything you asked and hopefully provide some feedback from you.
I just saw you are from Milwaukie about 35 mins from me. If you have questions, need help etc feel free to reach out. Pulling the FWD trans is easy to an extent.
It will have to be a FWD 4EAT out of either a Legacy, or an Impreza, the Loyal, and XT's used a different bell housing and won't bolt up to the EG33.
The Speedo will be off depending on the difference in the circumference of the SVX's wheels compared to the donor cars tires....some early Impreza had 13" tires... I think there were a few FWD Turbo Legacys, which should have the extra clutch packs, and "Should" be a better transmission...but were probably abused more too....
Ok I'm going to ask a very stupid question.
Here goes... What if you used a 4wd tranny and not hooked up the rear wheels? I suspect it will throw codes. But would it work at all ? Just inquisitive.
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
Tags |
fwd, fwd to fwd swap, non-svx donor at |
