Old 02-08-2019, 02:24 AM
Filip Filip is offline
Re: 3rd and 4th gear are not engaging + weird smell
Originally Posted by RisingPhoenix View Post
The 'BANGS' tell me that the ATF oil is pretty well broken down. The brake bands may be 'getting weak'
Here's how to test the transmission to see if it's an oil problem or a *transmission* problem:
Safely raise all 4 tires up off of the ground with jackstands, apply throttle from first to 3rd (I did this in a dealers shop one time) and if it shifts 'smooth' you probably have weak brake bands or they need adjusted..BUT if it shifts hard or *BANGS* (no load) while shifting, it's definitely the oil is bad. (Even if it looks good)
Hello RisingPhoenix, it is really hard for me to believe that, after such a long time and all this mysteriousness, the cause of my problem could be so trivial
Maybe all the time, I can't see the forest for one tree
Old 02-08-2019, 02:00 PM
Maybe all the time, I can’t see the forest for one tree
Exactly Filip,
Good thing that on two counts you have resisted being told how to suck eggs. LOL
Take heart that whatever the outcome, the thread has enabled you to practice your second language and your posts indicate that you should have no qualms in this respect.
Old 02-09-2019, 01:34 PM
Cheers Trevor, you are good guys here. My decisions were not always best, but its mainly because i underestimated preparations before buying. But if i would have been prepared, i wouldn't start this topic and language skill would decay.
Tags
burn, gear, shift, smell, transmission
