Old 09-25-2002, 07:11 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
mayday mayday tranny going down !! =<
well the transmsion is starting to go i think.. it slips off the line it will rev like 2,000 rpm and then thump in.. and also the gear are sliping and shifting funny overall the tranny feels difrent..
i have had nightmares of this day coming.. its a 92 subaru svx with 93k on it and has the external cooler put on it for the tranny also..
im going to bring it to aamco transmsions for a check up during my lunch hour here but im shure they will way they need to take it apart.
i had the tranny fluid changed abought 25,000 miles agop it still drives and all just tranny acting weird..
im not shure what to do u guys have any sugestions.. i might just do a 5 speed swap.. or sell the car in all. ill find more out later on today
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 09-25-2002, 08:49 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Re: mayday mayday tranny going down !! =<
DO NOT take it to AAMCO. Those people know jack about SVX.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 09-25-2002, 08:58 AM
Mr. Pockets's Avatar
Moderator
Re: Re: mayday mayday tranny going down !! =<
While that's likely true, each shop's personnel have different levels of capability. Our local Aamco seems honest and pretty good at what they do.
Just because it says 'Aamco' on the building doesn't mean that the people inside don't know what they're doing.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 09-25-2002, 08:59 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I'd say that it depends mostly on the people that work in the shop that make the difference.
Old 09-25-2002, 09:00 AM
Green1995SVX
The manager of the AAMCO in Lancaster, PA has an SVX. Sounds like the perfect car to own if you manage a tranny shop...
Mike
Old 09-25-2002, 09:02 AM
well im bringing her down on my lunch hour im thinking torque converter is going but who knows, i just want them to check the tranny bands see if there not loose...cabless..fluids and all. i know it has fluid for shure checked it already..
u guys have any sugestions,
Old 09-25-2002, 09:29 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Re: Re: mayday mayday tranny going down !! =<
Tru dat, homey. Unfortunately, auto repair franchises are not like McDonalds, where you can be fairly sure a Big Mac will taste the same in Walla Walla as it does in Timbuktu.
Case in point: I would not trust my mechanicals to the Goodyear shop in Evansville which is one block from my office, but will drive my car two hours to the Goodyear shop in Louisville, KY and have every confidence in the person who works on it.
Randy Johnson
Mike Davis -- at Reading VI
Old 09-26-2002, 07:52 AM
i think im going not do the 5 speed swap too much work involved and not shure if its really worth it.."but 240 hp AWD 5 speed sounds nice and put in the hi 14s"
i went to aamco yesterday it was on the way home they where a joke they wanted the car for 3 hours !!!! and charge me 45.00 just too telll its broken and they have to rip it apart. i think not..
there is a family mechanic of ours that has been verry good im probably going to let him do it. he saying its going to be between 1,300-1,800 for a full rebuild and new torque converter.
i will probably have the valve covers gaskets replaced also at the same time since the tranny will be out.. perfect timing.
come to find out its the same auto tranny in the nissan pathfinder wich i knew.
i used sythetic tranny fluid whene i changed it last .. the old fluid looked pretty dirty and was changed around 25,000 miles ago i never had any slipage.
Old 09-26-2002, 07:54 AM
have a question also need some svx expertise..
whene i have the rebuild done should i consider difrent gearing.. in any upgrades i might wanna do or check into ??
also the AWD ahs been acting funny like its spining the frount wheels more then anything should i have new cluches put in there also or does it include it in the rebuild?
Old 09-26-2002, 08:11 AM
svx_commuter's Avatar
The rear wheel drive may not be working cause the transfer valve is bad, a common problem. You should leplace that and the other solenoids while you are in there.
I have thought about getting the valve body taken apart and cleaned but it is a lots of time job. May be worth while doing if a lot of clutch material has worn off. There is a small screen in the body.
If the planetary gears or front diff is bad it will be extra. A rebuild from Subaru would cover them both. If you've driving hard without rear wheel drive the front diff may need some work.
Old 09-26-2002, 01:35 PM
I_Alcyone_I
if your going to be replacing the diffs it would probobly cost about the same as getting the 5 speed from smallcar. They have financing available too.
