Old 03-15-2014, 07:51 AM
shotgunslade's Avatar
Subaru SVX on Youtube Drive Channel
The SVX is discussed on the latest AfterDrive segment on Youtube. The segment is called "What are the Best AWD Cars you Can Buy For Under $30,000." Here is the link, with the SVX discussion starting about 18:58.
https://www.youtube.com/watch?v=GdIANn6oO3c
I'm proud to say that they mention my SVX for sale listing on Autotrader, citing the degree of insanity that would lead someone to put that much time and money into an SVX. But, they both say that some day it may pay off.
Old 03-15-2014, 02:00 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Re: Subaru SVX on Youtube Drive Channel
yeah cool, your car was mentioned around after 20 mins.
I think there're still some nice AWD cars they didn't mentioned such as Suzuki Kizashi is one of my favorites.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Tags
youtube
