#31
has anyone put some lightwight sparco's or something in an svx?
any word of how the fit or anythign?
SV What? |
#32
i've asked that like 3 times... no response, but i'd like to know too...
svx: the most effective diet (distant memory) mr2: diet on the diet (on the chopping blocks) urs4: looks stale, but good performance... hoping this one will last.... but too bad it didn't mrspyder: gotta have a drop top in cali... always looking for a reliable 5spd svx... |
#33
So, if the clutch and flywheel (26.5 lbs for stock flywheel weight) weigh about the same as the torque converter and flex plate the weight savings should be about the difference between the automatic and the manual. Anyone have the actual 5 speed weight? Small Car Performance told me the whole set-up reduces the weight by 65 lbs. I would believe it saves closer to 100 lbs. but not 200 lbs.
cbx-man '92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter '92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft '80 Honda CBX in-line 24 valve 6 cylinder |
#34
I'll try and weigh one tonight
before the bride gets home. She takes a dim view of using the bathroom scale for garage affairs
I've moved enough of them around last weekend, I should know. They weigh enough to make my back hurt from hoisting one into and out of my VW wagon. Todd
Down to none |
#35
Troy 1992 SVX LSL "Serenity" 250,000 miles! I don't care, I'm still free, You can't take the sky from me... |
#36
Re: I'll try and weigh one tonight
#37
thanks todd
#38
Todd
Down to none |
#39
Pulled a clandestine weighing
and some of you recent Stebro owners aren't going to be happy!
Stock muffler w/tips - 36.5 lbs Stebro muffler - 35 lbs Cable operated manual trans ('91 Legacy) - 119 lbs Hydraulic operated trans ('02 WRX) - 129 lbs Stock Legacy Outback flywheel - 23.5 pounds SVX hood - 48.5 lbs SVX wheel - 20 lbs I'll be building a comprehensive spreadsheet detailing SVX component weights in the near future. Next up; stock struts vs Ground Control coil-over/Koni struts. Todd
Down to none |
#40
Todd,
I personally weighed the SVX wheels with the center hub & bolts about 3 years ago. It weighed 17.5 lbs. I posted this on the Yahoo site years ago.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
#41
Interesting. I've always heard from members weighing the wheels that they were 20 lbs, right on with Todd's.
Also saw a couple posts on Stebro vs. stock system weight though and it came out with a little more difference.
#42
I also heard somewhere in an old thread here that the power seats weighed closer to 200 lbs. That seemed ludicrous to me at the time but 45 lbs -50 lbs seems rediculously light as well. Seems to me Sparco seats wouldn't save much weight at all.
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX) Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting. Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well. You can tell the lack of craftsmanship by the wrinkles in the duct tape. |
#43
they might not save much weight, but a little weight goes a long way, if you have 10 places in the car to remove just 5 lbs each you have removed 50 lbs, and every bit helps
you guys know about the 3000gt right, how they shortened up all the wires in the car to not have any slack and freed up like 70 lbs
SV What? |
#44
Look in my locker under "Leather replacement project" and you'll see that I had the seats out and then into a hundred pieces too.
I was able to lift them up and out of the car, up a flight of stairs to my apartment at the time, etc, so I know they aren't 200 lbs (wish I was that strong though ). Next time I have them out I will weigh them just for reference though, maybe 40-50 is a bit light. Todd's spreadsheet sounds like a great idea.
#45
Re: Practical Weight Reduction?
Hello,
I am doing this practical reduction to my car currently. Usdm92 model what is being converted into a european model. - power seatbelts to the manual versions - airbag - sound insulation from the floor, under seats, trunk. Perhaps from the roof too. - rear window wiper system/tank - wiring loom, i change aftermarket ecu for car and redo all the wiring. - cruise control unit, vacuum pump and cable what pulls it. Replacing it with modern solution. - trimming steering column and changing steering wheel to 3spoke one. - Plenty of more places too. Plenty of futile steel brackets. Goal would be drop about 200-300lbs off atleast of that 3550lbs |
