Strut Mounts
I am somewhat confused with what part number I need after going to different websites. I have a 95 SVX L and need at least the right front strut mount which is shot. I want to replace the front left as well if possible. Part number 20361PA000 is not in stock anywhere. Any help appreciated in advance.
Mike
95 Pearl Blue L |
Re: Strut Mounts
They are NA. You'll have to find a good used part. Try these guys in Rancho Cordova CA. They are good to deal with and have about a dozen SVX parts cars.
http://sspparts.com/
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, |
Re: Strut Mounts
Perhaps Javan worked out a solution.
http://www.subaru-svx.net/forum/showthread.php?t=64355
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. |
Re: Strut Mounts
I have the koni strut setup up from motorsport warehouse with the lowering springs. So does this mean the STI strut mounts will work with my car? If anyone knows?
95 Pearl Blue L |
Re: Strut Mounts
The part number I listed above is for the rear strut mounts. I need 20320PA011 for the front L/R. There are diagrams on here I found through a link in another older thread that show pics and part numbers. Whew. I will try to order tomorrow through my local dealership to get the parts faster.
95 Pearl Blue L |
Re: Strut Mounts
I did the Koni inserts with Zoom lowering springs -
http://www.subaru-svx.net/forum/showthread.php?t=64292
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Thread Tools | |
Display Modes | |
