Old 08-09-2010, 05:49 PM
Re: Engine Bearing Failure
Originally Posted by TomsSVX View Post
Assuming the bolts that have seen thousands of heat cycles are equally different from their OEM specs... Not to mention the stock rods are heavier than they could be and their weights I am sure are not quite as equal as many would prefer. it would be who of whomever is building an engine to simply replace them with better ones. Tom
I was assuming that here an engine build in preparation for power modifications is involved, in which case surely new bolts would be fitted. You have not got the point.
When a bolt is not stretched adequately, room is left for further stretching under load. This results in continuous movement and hence fatigue. Manufacturers tolerances can often be too conservative.
My source of information, the late Bruce McLaren, as a result of a conversation relative to his experience gained through his company's successful racing in the US and Europe. He was describing a specific fix for what had become a serious problem.
Old 08-09-2010, 06:49 PM
The point missed is that the rod bolts are not serviced separately by Subaru. in which case aftermarket fasteners would need to be installed. At this point, an engine built for power, it is my recommendation not to bother fitting new hardware to an old rod, rather install better rods which come with better fasteners.
Old 08-10-2010, 10:43 AM
NeedForSpeed NeedForSpeed is offline
Point well taken, also, installing new bolts in old rods, especially bolts from another manufacturer, distorts the rod housing, the rods would require resizing to insure roundness.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 08-10-2010, 05:25 PM
Provided the exactly correct sized bolts are installed in old rods without any other alteration, in no way can this alter the angle or relative degree of compression exerted between the two sections involved and as a result cause any new form of distortion.
The point made within my posts has now been completely misconstrued.
Old 08-10-2010, 05:34 PM
I have remanufactured thousands, yes thousands of connecting rods. The only 'exactly' correct bolt with an exact 'press' fit is the OEM, if you are lucky. My experience is that aftermarket bolts often vary, many requiring a great deal of force via press to install. Granted, not much harm in that area of the rod bearing, and likely all would be okay, but a perfectionist I am. If I changed bolts, I would carefully measure the rod, before, and after.
I was not responding to your posts, only to Tom's last post mentioning the fact that buying new rods was a better deal in the long run than purchasing better bolts for a stock rod. thanks
Old 08-10-2010, 05:57 PM
I have to say that in view of your experience, I am concerned that you would under any circumstances, consider forcing a bolt into a restrictive space as there will be immediate distortion, with extra occurring at operating temperature.
Sorry if I inferred that you had caused this problem. This was not intended.
Old 08-10-2010, 06:26 PM
This is exactly the point, rod bolts typically have knurled shanks, a press fit is intended, into a 'restrictive space'.
When new bolts are driven in, due to interference fit, when the rod cap is installed and torqued to specs, the rod can be distorted compared to the original production. The rod housing may not be perfectly round or measure to spec dimensionally as desired. If you understand the distortion, you should grasp the reason I gave to have the rod re-machined.
Any time a fastener that secures a housing, the housing should be re-measured and re-machined accordingly. The intent of aftermarket rod bolts is more clamp load, could that have an effect on the housing? Of course it does.
A round and true-to-spec rod is necessary for bearing life. Sometimes the focus is only on measuring the crankpin and the rod bearings. The rod housing has a spec that is carefully measured by professional engine builders.
Old 08-10-2010, 07:16 PM
Every conn rod stud, and I do mean stud not bolt, is pressed into the rod. All of them...
Only conn rod bolts are not, and even then they use a wave type design to align the two halves.. that is unless they use dowels of some sort built into the rods themselves like the STi rod and Eagle's method of hollow alignment shells.
This again, one of many reasons NOT to use stock con rods in a built motor... So why try to state a case to the contrary?
Old 08-10-2010, 07:25 PM
This has turned up some information that will be of general interest and it is therefore worth continuing as there are several doing engine rebuilds on a hobby basis.
I now note that the typical rod bolts are knurled and a press fit is intended. OK if the knurling is such that there is no significant forced expansion, but to a degree requiring a power pressed fit appears stupid. The mind boggles at the sense of this and indeed the actual purpose or need for the knurling and an interference fit, which can distort the rod. What exactly is the manufacturers reasoning?
I exactly understand “distortion” and therefore ask, why accept that there will be distortion and re-machine the rod to compensate? In circumstances where no other bolt is obtainable, why not remove the knurling so that the bolt is free floating and all is correct? Raised knurling can have had no beneficial effect in respect of bolt strength. Surely no one uses these bolts in a modified engine.
Old 08-10-2010, 07:36 PM
There has previously been no previous mention of a conn rod stud.
Furthermore none of this has anything to do with my original post and comments, which remain valid and accurate. This discussion is for the birds, I leave you to it.
Old 08-10-2010, 07:47 PM
Cam Cam is offline
I was advised to reuse my stock rods, and NOT use tri metal bearings. I used bearings supplied to me by LAN. So we shall see whether or not the stock rods hold up in a build. 11:1 compression ought to figure it out real quick...
When the number 5 bearing fails in our engine, I have a feeling it is an oiling issue. Possibly the Rod in Desertrunners engine can be carefully inspected and ultrasound-inspected to look for any abnormalities in the material of the rod. I would think that there should be a non-destructive way to find out if the rod or the fasteners themselves were distorted. I think it would be worth the money to find out if possible.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 08-10-2010, 08:14 PM
We are talking about the EG33 which is equipped with conn rod studs... WTH are you going on about??
Simply admitt, if you were building a high revving engine, you would as soon switch to a better rod than fiddling with inferior bits for no good reason other to make an argument and maybe save $300 on a multi-thousand dollar engine... Making sense anytime soon would be who of you
I know what you were advised. Different strokes for different folks.
Old 08-10-2010, 08:24 PM
Cam Cam is offline
It is important I point out that my engine will go to 7k rpm max. Any higher and there is no question I would have gone with Eagle Rods. I do not like how others have had so many cooling problems and bearing failures when they push the rotating speeds.
Cam
'92 Ls-L Dark Teal
Old 08-10-2010, 09:59 PM
Nature of the modifying beast I guess... One thing to take into consideration as well... You are not going to push more horses out of these engines and expect them to run 100k trouble free... Its less about picking the parts that will last the longest and more about the parts that will do the job the best.
