Old 11-19-2004, 06:39 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
its verry hard to have a handling car and a drag car
the turbo set up is huge in set ups also and suspensions set ups are totally diffrent
u have to ask your self,
do u want a corvette killer or do u want road course car? then build from there
also another alternative, not a favortie of mine is go 2.5" exhaust anything thats cheap then get a external waste gate or o/2 dump tube also,, its not loud unless u spool the turbo up, but whene it spools up u will wake half the neighbor hood up,
the set up i was after was 272 cams, fp green or 20g turbo in a td06 housing 720s and so on,
i still have a 1st gen head off the old 92 u can have or im just throwing it away its missing the cams and cam sleeves so not much good but for a paper weight.
u can easily spend as much doing brakes, and handling then on engine work
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 11-19-2004, 10:13 AM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
A set of decent coilovers can be had for around $250. They'll drop you car a bit too which will also improve handling. Depending on the amount of drop you may need camber kits. Once you get them installed get a 4 wheel alignment.
For $2k you could make a pretty fun DSM that should run in the 13's.
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
