Old 04-12-2004, 09:36 AM
wynndi's Avatar
wynndi wynndi is offline
Send a message via AIM to wynndi Send a message via Yahoo to wynndi
Need TSB For Wheel Bearings
Anyone have a copy of the REAR WHEEL BEARING TSB? I'm ready to paper-cut my local Subaru dealer with it as I am bringing in my '96 for a 3rd replacement in 11 months.
Grrrrrr.
-Thanks!
Dave W.
______________________________
1996 Redd
Old 04-12-2004, 11:17 AM
Porter
Sounds like a hub problem. It's probably not the wheel bearing itself causing your trouble. Could be the hub or the housing itself.
Old 04-12-2004, 11:19 AM
wynndi's Avatar
5,000 miles ago, they replaced the housing & bearing.
Could alignment be a contributor? Car tracks straight and dealer mech has not recommended an alignment.....
Dave W.
1996 Redd
Old 05-19-2004, 11:37 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Hi Dave,
I am having rear wheel bearing problems and just wondered where you took it (Cherry Hill Subaru??). I f so, I need to find someone else to do it based on your experience. I think the guys at Grove Street Auto in Haddonfield are good. I could order the bearings online. Any suggestions on who would know best how to do this?
Michael
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 05-19-2004, 12:12 PM
LarryIII LarryIII is offline
Dave,
What dealership are you using. Parts are supposed to bre guaranteed for 12 mos.
I will look for the TSB tonight at home.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 05-19-2004, 01:24 PM
wynndi's Avatar
Cherry Hill Subaru. They did the 2nd replacement free, as they should.
So far, it's pretty quiet, but, if it kicks up again I'd love to have a copy of the directive to wave at them.
Their service, not including the bearing issue, has been good. they were very polite about the replacements, but it was still a hassle being without the SVX....times 2.
Dave W.
1996 Redd
Old 05-19-2004, 02:17 PM
shoden's Avatar
shoden shoden is offline
Is this the service bulletin you're looking for?
If so, I've got the PDF here: New Procedure for Replacing Rear Wheel Bearings
Shane
92 SVX - Sold
98 BMW M3 Sedan
89 Honda CRX Si w/B16 swap
91 Honda CRX Si
Old 05-19-2004, 02:58 PM
lee lee is offline
this might be what you're looking for
This is a cut and paste, there were other topics (about 6 pages worth). The bold text below is my doing, not Subaru's.
Technical Service Bulletin # SHU0495 Date: 950401
Service Helpline Update - April 1995
SERVICE HELPLINE UPDATE
APRIL 1995
Replacing AWD Rear Wheel Bearings
REPLACING AWD REAR WHEEL BEARINGS ON LEGACY, IMPREZA AND SVX
When replacing rear wheel bearings on All Wheel Drive LEGACY, IMPREZA, and SVX vehicles, be certain not to overtorque the lateral link bolt that secures the two transverse suspension arms to the wheel bearing housing. DO NOT AIR GUN THE BOLT OFF. The proper torque is probably less than you think. Since the torques are different for the different models and years, refer to the appropriate manuals for the proper specs for the vehicle you are working on. If this bolt is overtorqued, it can deform the housing and may lead to a repeat failure of the wheel bearing.
If you encounter a repeat failure of a rear wheel bearing occurring in an unreasonably short amount of miles, the housing may have been deformed during the first repair. Replacement of the bearing and the housing may be required.
There are some other things to remember when working on the wheel bearings. Never loosen or tighten the axle nut with the weight of the vehicle on the wheel. The vehicle should be in the air with the wheel removed prior to loosening or tightening the axle nut. If this precaution is not taken, damage to the wheel bearing may occur. The axle nuts are NOT reusable. A new nut should be used with the new bearing. Always insure that the new bearing is properly packed with suitable wheel bearing grease. The grease that the bearing is shipped with is NOT sufficient.
Always use the proper special tools to install the bearing and torque the axle nut to the correct specifications.
Old 05-19-2004, 03:09 PM
Dave,
How much does CH Subaru charge per bearing with labor?
Does the PDF file cover SVX as well...it doesn't mention it.
Michael
Two-owner:169K
2008 Toyota Prius
Old 05-20-2004, 09:48 PM
wynndi's Avatar
About $410 each. I didn't see the SVX mentioned either...I'm still looking and am certain that I've seen it before.
Dave W.
1996 Redd
