Old 10-08-2007, 08:58 PM
Trevor's Avatar
Trevor Trevor is offline
Originally Posted by crazyhorse View Post
How thick is the intake casting? If it's more than 1/4" anywhere that a sensor would work, you could just drill & tap the aluminum. After all, it's not like the sensor's going to be under any real stress.
Otherwise if there's a good, flat surface, you could bolt on a steel plate, with a bung welded to it. Use some epoxy to seal it, & viola.
A major problem exists in that there must be no heat conducted to the sensor from adjacent components, via any form of mounting.
The element must be arranged to be insulated from extraneous heat and be in free air. This factor will have a profound affect regarding a practical possible location, as well the make up of the sensor.
The physical aspects of the MAF provide food for thought.
Trevor, New Zealand.
Old 10-08-2007, 09:13 PM
sicksubie's Avatar
Look at the AEM temp sesor that I found on ebay. It is a wire probe that extends into whatever the chamber is that you are tapping. From looking at it I believe that it would be free from reading parasitic heat from the manifold. What do you think, Trevor?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 10-08-2007, 10:12 PM
Trevor's Avatar
Sorry but no details available as "the item has ended". However if it is made for the job surely it should be OK. Does it comprise a thermocouple?
Do a for data and possible experimentally constructed gear. Temperature measurement is involved in several hobby projects and I am sure I have seen articles on making up stuff. There are temperature sensors available for use with a multi meter, but such would have to be mounted in some way and a conversion chart is usually involved.
You are delving into an area of considerable interest and figures would be worthwhile. I would not be surprised if it will prove difficult to better the OEM set up, in respect of NA engine.
Let us know how you get on, Trevor.
Old 10-08-2007, 10:33 PM
sicksubie's Avatar
The item has not ended. Look at the second URL listed. The auction does not end for 2 days. AU and NZ aren't THAT far ahead of us
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-08-2007, 10:56 PM
Speedklix's Avatar
Locker Link Solution
Now that I see what you were talking about earlier Bobby, the 2nd sensor looks like the way to go.
tap manifold, use some hollow threaded rod instead of bung, and rig up a translation box to match the output of the new sensor to the output of the old sensor. Which is the part I don't know enough about. I've only done that sort of thing following instructions for a specific application. That was for getting the touchscreen in my reatta designed to read data from a series 1 3800 to display the correct data from a series 2 3800 turbo
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 10-08-2007, 11:05 PM
Speedklix's Avatar
then there is also this...
http://cgi.ebay.com/ebaymotors/AEM-A...QQcmdZViewItem
-Mike
[SIGPIC][/SIGPIC]
Old 10-10-2007, 08:42 PM
sicksubie's Avatar
I am getting this http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29 and then sort of doing what Speedklix said above. I am not sure if I will wire it into my climate control. I would like to but need to know more about the climate control first.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-10-2007, 09:58 PM
Trevor's Avatar
Unfortunately the offer does not provide enough information to enable informed comment.
What is designed to be inserted/mounted into, a heat conductive or an insulating material? I can see no evidence of thermal insulation between the probe and mounting. I would think that it incorporates a thermistor.
Old 10-10-2007, 10:03 PM
Trevor's Avatar
Originally Posted by Speedklix View Post
Still not enough information, but this looks to have thermal insulation between mount and probe.
P.S. Best option of the two. Can you do some research and find more information. Is a thermistor incorporated? If so what are its specifications? What is it designed to mate up with?
Old 10-10-2007, 10:13 PM
Trevor's Avatar
Years ago I used a walmart/lowes outside temp probe inside of my airbox.
I used the readings to change my ram air setup.
This makes sense, but the fact that the air will be fast moving, may upset the calibration. However this is not important, provided that the main object is to secure readings as a means of comparison.
It must be accepted that any transducer will require time to react and this should allowed for accordingly.
Old 10-10-2007, 10:21 PM
Trevor's Avatar
Not the better of the two offered. See my comments.
Trying to utilize the climate control in some way is not a good idea.
Hold off for a day or two and I will try to come up with something.
Old 10-10-2007, 10:35 PM
sicksubie's Avatar
Alright... Will do.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-10-2007, 10:41 PM
Trevor's Avatar
N.B. Those interested should back track, as there a several posts now involved.
