SVXBot
Old 04-03-2018, 05:39 PM
Tmazzola12 Tmazzola12 is offline
*** Doing Rear Subframe Any Pointers ***
Bought most every bolt, washer, bushing, nuts and caps OEM
SSP should provide Rear subframe with trailing arms
Going to ask for support plates
New calipers
Hopefully sway bar and brackets
* Now as far as I know the frame is bolted to the body
The axel shafts shouldnt have to leave the diff
Nor the gas tank
-prob use ramps, jack stands, etc.
Do I have to remove the exaughst ?
Will I need any special tools ?
Do the bearings have to be pressed into hubs ?
*Can I use clamps to rewind calipers and
does proportioning valve need to be reset
Pnuematically if reservoir goes empty ?
Any knowledge would be welcomed thanks
Tommy 1996 LS-I -Polo Green - #467
Old 04-16-2018, 09:03 AM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
Re: *** Doing Rear Subframe Any Pointers ***
Same here. did this go anywhere?
Beware, the mounting bushings are most likely not available as parts..
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 04-17-2018, 07:27 PM
Have a whole rear suspension out of a doner car on the way
I bought all the bushings/ bolts left in the system around here through a dealer
Old 04-18-2018, 04:56 AM
I bought a rear sub-frame from SSP a couple of years ago. It was in mint condition. It looked like it was removed from a new car.
1997 Bordeaux, 1992 Claret (parts car) 2011 BMW 535i GT Xdrive, 2006 Nissan X-Trail SE 4WD, 2012 Moto Guzzi Norge GT 8V, 1982 Honda Nighthawk 650
Old 04-18-2018, 08:14 AM
jetboy's Avatar
SSP refused to sell me a subframe...
The mounting bushings were never separate parts. If they are worn, you need new ones and they are not available anywhere.
Please check the condition of yours, the solution is not that expensive if we share the expense (Poly bushings).
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 04-23-2018, 07:10 AM
True!! Thing is mint
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
2001-2015 SVX World Network
