Old 09-07-2007, 09:43 AM
Jefus Jefus is offline
Jeff Williams
Send a message via AIM to Jefus
99 rs front and rear diffs, 4.11
I had the wrong ratio on my old post so re-posting
I have a front diff out of a 5 speed 99 2.5 rs tranny and a rear diff. that I had in my 92 svx. the rear diff is a hybrid. the ring and pinion are 4.11 final out of a rs and the lsd in it is from the OEM svx rear diff. It also has a small drip around the seal on the front. make me an offer on these parts I need to get rid of them. jefusj@yahoo.com.
Old 09-09-2007, 12:17 AM
Nevin's Avatar
Nevin Nevin is offline
Forgive my newbie question, but would just changing the diffs throw off the speedo? If not, then yes... I am interested. Would you happen to have pictures?
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 09-09-2007, 04:08 PM
Jeff Williams
i couldnt not give you a deffinate answere on that one, you should do some research on the subject.
Old 09-09-2007, 10:05 PM
Nevin's Avatar
No problemo. THanks just the same!
Jesus is the remedy
Old 09-19-2007, 08:52 AM
CFAS CFAS is offline
changing the diff will change your speedo reading, speed sensors usually readd off of the transmission. i know someone who might interested on these, ill spread the word
Old 09-19-2007, 09:58 AM
The speed sensors that drive speedometer in Subaru's read off of the axle rotations, so they're not affected by the final drive ratio.
