Old 03-12-2014, 05:45 PM
stiguy's Avatar
stiguy stiguy is offline
Timing jump?
So I changed the water pump the other day. All was good after. But then it started running badly. It runs relatively smooth but when driving there is no power and there's more of a drone sound in the exhaust. So I'm thinking it jumped timing or bad spark plugs. Any suggestions?
#1 1994 Ls ebony parts car-rip
#2 1994 L laguna blue - sold
#3 1992 Lsi pearl white - sold
#4 1992 Lsi pearl white -Ate two engines - Rip
#5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree
#6 1992 Lsi custom orange parts car
#7 1992 Lsi green 4.44 swap. Currently for sale
#8 1992 Lsi custom pearl white. Project car... sold
#9 1992 Teal 4.44 swapped... sold
#10 1995 Laguna Blue. Sti 19 wheels,
#11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂
Old 03-12-2014, 06:43 PM
Re: Timing jump?
1st rule. Go back to the last thing you did.... My guess is the timing is off a tooth. How does it sound when it starts...
Old 03-12-2014, 07:02 PM
Re: Timing jump?
Timing. Make sure you preload the tensioner. You may and should consider a new timing belt if you didn't replace with new.
Old 03-12-2014, 07:12 PM
stiguy's Avatar
Re: Timing jump?
True true! I did mark the belt and sprockets before taking the belt off and they all lined up.
Yeah I will change the belt eventually just been broke and the water pump wasn't cheep
Old 03-12-2014, 07:18 PM
stiguy's Avatar
Re: Timing jump?
Kinda gurgles on start up and takes a few sec longer to start
Old 03-13-2014, 11:29 AM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Re: Timing jump?
You can get a good timing belt kit on ebay for less than $150, including all the idlers.
http://www.ebay.com/itm/SUBARU-SVX-3...875017&vxp=mtr
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 04-02-2014, 10:56 PM
major7venth's Avatar
major7venth major7venth is offline
M7
Re: Timing jump?
Sounds like timing belt is off a tooth. Must first mark timing belt cogs,crank and both cam pulleys with chalk or grease pencil and then re check and re check again by counting teeth on both sides of center crank. 53 teeth each side if I remember correctly.good luck with it.
