Old 06-22-2018, 04:04 PM
shotgunslade's Avatar
Music to my ears
A video that I uploaded to Facebook. A Sunday morning drive on NJ backroads in my '94 Emerald, with all the mods on my signature. A little long and perhaps the beginning has too much straight roads. The curvey bits at at the end. But listen to the sound. It's much more engaging than my Porsche 911 Turbo S.
https://www.facebook.com/danielh.nal...933967631/?t=3
Old 06-23-2018, 09:33 AM
wdb wdb is offline
dances with roads
Re: Music to my ears
That does sound sweet! Even if I did have to go to Facebook to see it. ;-)
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 06-24-2018, 04:13 PM
That is music to my ears as well. It really sounds great. Thanks for sharing the clip.
Old 06-26-2018, 06:01 AM
Huskymaniac's Avatar
Uses the ignore feature
You bought it back?
Tony
Old 06-27-2018, 08:19 PM
Yep. Couldn’t live without it. Now about to do the WRX 4-pot/Tribeca rotor big front brake upgrade. An SVX is a hole through which you pour money into potholes in the road. How much have you spent on your SVX. In the words of Carl Sagan: “Billions and billions....”
