Old 02-08-2003, 03:53 PM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Originally posted by Seraph
Yes. I believe the European spec SVXes had the powermode button and manual switch. Manual switch is on the array of buttons and powerswith is where our (US Specs) manual switch is located.
L
The UK spec cars have an 'econ' button on the gear lever. This seems to disable the power mode, lower the rev limit and make things generally sluggish. Does not seem to have a great effect on fuel economy.
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 02-08-2003, 04:04 PM
Originally posted by svx_commuter
I think the ZOOM is controled by the inductor valve between the two halves of the intake manifold. Sometimes it does its thing and other times it doesn't.
There is a write up on this in the SM that explains this valve but I have not found the section that talks about how to trouble shoot it.
I think it would fairly easy to hook up a volt meter to the ECU pin that works this. Then it would be easy to tell when it comes on. It would be the major factor for increasing the HP along with some extra GAS cause it puts more air in the engine.
also a somewhat common problem with 928's - a sticky "flappy" valve that selected between the dual induction paths. is the SVX's valve electrically, or vacuum actuated?
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 02-08-2003, 05:59 PM
alacrity024
i think that i can settle this "32 extra hp in power mode" quarrel. as is clearly indicated in the following totally legit dyno chart, power mode affords the svx driver an additional boost of high-end horsepower. note that at lower rpms, power mode suffers a minor loss of power. torque graph was not avaliable because the dyno blew up when we tried to run power mode.
oh, this is with the FWD fuse in, so assume a 5% loss of horsepower when AWD is implimented.
Old 02-08-2003, 06:02 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
What is the peak HP? and at what RPM?
I'll try to drive in that range all the time.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 02-08-2003, 06:06 PM
alacrity024
Sorry lwin, the scan of my totally legit dyno chart must've clipped the numbers off. in normal mode, peak HP (~170-180 at the wheels) generally comes on at about 5400rpms. The interesting thing is that in power mode, the peak power (~380hp) doesn't start to come on until about 6k rpms..
-adam
(totally legit here)
Old 02-08-2003, 06:22 PM
svx_commuter's Avatar
That is a vacuum actuated valve. It has a reservoir with a check on the inlet and the solenoid valve is between the res and diaphragm for the inductor valve.
Old 02-09-2003, 12:36 PM
CigarJohnny's Avatar
-adam
Lol...What???
Old 02-09-2003, 12:54 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
So does the dyno chart truly confirm it? Or is it just the cause of the rumor? Im confused
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-09-2003, 03:54 PM
Alcyone SVX LSL
read what it says at the top of the "dyno" sheet
Old 02-09-2003, 04:47 PM
I am suprisied that you did not get the torque figures, as that is what the dyno actually measures. Can't you just do a redraw and call it torque Use a different colour, paint box has plenty
Old 02-09-2003, 05:37 PM
Speedklix's Avatar
Locker Link Solution
an old trick for 928's (which came mostly automatic, to the U.S. anyway) was to put in a parallel kickdown switch. i put a momentary switch on my deadpedal in parallel with the kickdown switch under the gas pedal. i could hold it down with the left foot if i anticipated a "takeoff." it would kinda trick the computer into inducing kickdown more readily, but other factors were involved (speed at which you hit the gas pedal, current speed, etc.) very far.
I got a White 89 Eagle Premier ES Limited from a tuner that worked for state police in IL near Chicago. It had something under the hood that looked like 2 cables for the trottle but one didn't go to the throttle body. Somewhere near the floor, the pedal would "click". Do it twice holding it the second time and suddenly I would get an extra 30-40mph.. very nice on onramps. I was able to get some noise out of the tire at most every speed I could hear out the window. never really understood it. It was also my first car, I wish I still had it today.
But anyway... 92 LSL - one of the reasons I got it was for the mysteriously faster stock track times. I think the answer to this little "mystery" exists in the computer. Or maybe oil pressure... You know how you lose power when you lose your rings. I haven't had this problem with losing power on a second "mash" but maybe it seems faster the first time because during the first "mash" the engine is just perfect and happy and all that. The second "mash" there has been a bit of friction and you are losing ponies in the mix, maybe you are loosing your compression.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 02-10-2003, 02:09 AM
A dynamometer can and will directly measure HP with a high degree of accuracy dependent only on the measurement of the electrical output of the driven dynamo. Also torque if the dynamo is as is usual arranged free to rotate against a lever and weight or calibrated spring.
But the Ò dyno Ò you pay to put your car on is usually based on a water brake and is not a dynamometer even though the title given it indicates otherwise. As Harvey has pointed out these machines can only measure torque with any degree of accuracy.
The HP readings which they produce are very much subjective and calibration is always in doubt as is repetitive accuracy. On top of this all the factors and limitations in respect of a road wheel driven device further reduce the prospect of accurate readings.
Old 02-10-2003, 05:37 AM
92 with POWERMAD button.
My late '91 car has the POWER button on the console. Last year, I drove the car with it on all the time, and I will give you my impressions of it.
First, a little debunking. Most of you are talking about what "feels" faster, the whoaaaa factor, not measured in any meaningful way. Top gear [D4] is a ridiculously high overdrive, so talking about lockup has no relevance. The gear is for cruising in, not accelerating, and in my unhumble opinion, top gear does not "feel" fast at any time.
The 4EAT box tends to learn your habits, and give you a smooth ride all the time. I hate this. I like to think I am a smooth driver. When I want speed NOW in D, the box thinks I want to go a little faster, and tries to speed up in D, not possible, or at least not too satisfying or safe. If I mash the pedal to the carpet it drops about two gears and puts on POWER mode. However, I don't actually want to be blasting off into the sunset at full roar, I merely want to accelerate past quickly and without drama. NORMAL mode does not give you this.
With POWER button pressed, the car is more responsive, and does about 2 to 4 MPG less. It is also more nervous, will hunt more for the appropriate gear. NORMAL mode assumes that D4 as quickly as possible and held for a long as possible is the appropriate gear for all occasions. In the words of our esteemed Chairman,
Bleeccchhhhh.
Regards the extra 30 odd horses, they don't exist. However, with POWER mode on all the time, the car feels about 50 hp better, and this is logical. It will shift down quicker to a low gear, and hold it longer. What you are getting is power to the road when you want it from the meaty part of the rev range, i.e. between 3 and 5 thou in 3 range or 2 range. The car feels lots lots faster. One other thing the permanent POWER mode did, it allowed me to preselect 3 by dabbing the pedal when about to overtake. In NORMAL mode with the present tranny I have, nothing short of carpet bashing will produce a lower gear.
Old 02-10-2003, 09:15 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Originally posted by TE1221
Does a pedal mash induce power mode for you guys? I never could seem to get the light to come on when i mash the gas, but it does downshift and go up to like 5000 rpm.
The only way I could seem to get the power light to come on is by tapping the gas twice and holding the gas down on the second tap.
Anyone experience the same thing?
A swift "wellie" to the floor induces power mode in my car, without fail. Though, I've heard of varying effectiveness of this method. "Blondeman" used the "tiptoe" method. Others have reported a slower pedal to the floor activating power mode. I'm guessing that "regular" driving habits may have an effect on how the mode is activated, since the TCU adjusts to "lowest common denominator" driving. Just a theory.
John, are you talking about the "IRIS," as seen in this cutaway?
(Iris is the large gold "disc" at front of top of engine)
Randy Johnson
Mike Davis -- at Reading VI
Old 02-10-2003, 09:35 AM
Yeah that's the baby, the inductor valve. They SM also referes to it as the 'Supercharging Valve". Section 2-7 of the manual has a description of how it improves the volumetric efficiency of the engine, how more air gets into the engine. It's a pretty neat feature on the SVX. I am thinking that it doesn't always do it's thing in the low rpm zone but hey no proof. There isn't any detail on when it opens and closes relative to throttle position. It is very interesting.
