Old 02-06-2003, 04:44 PM
Henry
*S*O*L*V*E*D* -- the mysterious front end noise!!!
SYMPTOMS
At 10-15mph, and with brakes off, rolling over a 1/2" bump generated loud banging.
ANALYSIS
Roll repeatedly over a bump to check which corner is generating the noise. Get the car in the air and compare the noisy side with the quiet side, item by item. Check all bushings (crowbar) for visible wear and excessive play. Check top strut mounts.
POSSIBLE CAUSES AND SOLUTIONS
Upper strut mounts - a modified lo-noise version was issued by Subaru. $200.
Sway bar bushings. $100
Subframe bushings. $250
Steering rack. $1,345,088.72 (after core charge)
Struts. $450
Missing brake shims. $25 plus labor
ACTUAL CAUSE
One of the bolts holding the brake assembly together was loose. Cost = $0.00
RESULT
Quiet - amazingly so. What a pleasure!!
Old 02-06-2003, 04:47 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Awesome! Congratulations.
Were the shims in place? If the noise comes back in about 300 miles, then the shims were not present and need to be added.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 02-06-2003, 04:52 PM
CigarJohnny's Avatar
Congrats! Isn't it a wonderful feeling?
Old 02-06-2003, 05:11 PM
Noir's Avatar
Noir Noir is offline
gratz. wish my life was so simple. another $2700 into the car. and i've had it for 4.5 weeks lol.
Old 02-06-2003, 06:11 PM
kuoh kuoh is offline
Re: *S*O*L*V*E*D* -- the mysterious front end noise!!!
You mean one of the caliper bolts? I wish it were that simple for my SVX. I did the brake job myself, so I know that they aren't loose. Still get the infamous "clunk" when going over bumps at low speeds.
KuoH
Old 02-06-2003, 08:17 PM
Henry
NOT A CALIPER BOLT
(confession time)
My son and I spent a few hours on it, changing the sway bar bushings and checking/tightening everything in sight, and it still clunked. It went to a local shop where the tech gave it back in no minutes - charged nothing (though I slipped him a ten) and off I went -- absolutely positive it would clunk again going over familiar bumps on my street. But the noise was gone!!!
I called to find out what the tech had done, but he had already left for a long weekend. The guy in the bay next to his said "A bolt in the brake assembly was loose."
Old 02-06-2003, 09:28 PM
DavieGravy DavieGravy is offline
That's good to know, but which one and where?
Old 02-06-2003, 09:34 PM
Aside from the two caliper bolts, what other bolts would be part of the brake assembly?
KuoH
NOT A CALIPER BOLT
Old 02-06-2003, 09:39 PM
I'm in suspense too!
Old 02-07-2003, 07:56 AM
Henry
I'll talk to the mech when he returns to the shop.
Meanwhile - we just put pads up front, and I'm positive that the two caliper through-bolts were tight. It was something else.
Old 02-07-2003, 08:35 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
And I thought you were in Washington State.
Randy Johnson
Mike Davis -- at Reading VI
Old 02-07-2003, 03:32 PM
Oh, let me check!!!! Yep, you're right Randy - I am in Washington State. Now how does that work. Both in Washington State and in suspense at the same time!!! Go figure!
Old 02-07-2003, 03:35 PM
Aredubjay's Avatar
E=ES Squared.
Randy Johnson
Old 02-11-2003, 05:47 PM
Henry
The straight scoop....
Today I visited the mech who did the 1-minute fix.
There are two bolts through the caliper assembly. To change pads, the threaded one (smaller) is removed, and the entire assembly pivots around the other one. Perhaps the easiest pad change in the industry.
The PIVOT bolt is the noisemaker. Evidently it can look tight, feel tight, but not be tight. I would have SWORN it was tight after we put pads in the car, and even checked it once or twice while searching for the noise. The (non-Subaru) mech insists that he's had that front end noise on other SVXs, and even after other mechs have thrown up their hands he walks in and tightens what appears to be a tight bolt. Voila! Noise is gone.
He says an important diagnostic clue is that the noise DISAPPEARS when the brake is very lightly applied. When he hears that he just reaches for the right tool and goes for it.
It's 500 miles later on my car, and rolling over a bump is still a silent experience.
Old 02-11-2003, 06:33 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
Henry,
Give us a long term update in a couple of weeks, will ya? I'm fighting the same noise, and it's WAY too cold for me to work on it in the garage to try it, until Toronto thaws out in March...
VK
Eh!
