Bracket for PS Pump
http://subaruparts.com/parts/1997/SU...ow=1&maxRow=10
I found that my Bracket is cracked, and long bolt is bent. Can someone hook me up with the parts for #2, 4, 16, and 17 in the middle diagram please. My Pulley is spinning free, but if you have that, then I'll take it also. Thanks Folks
The Worm ![]() _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
Re: Bracket for PS Pump
Found this on eBay..Seller confirmed it comes with everything shown in picture. Pretty decent price...I'm not affliated with the Seller who is in Montana.
http://www.ebay.com/itm/321315663295...S:1123&vxp=mtr |
From the Ebay ad:
used power steering pump from a 1999 outback 4wd wagon will fit and ej powered subaru, maybe the svx as well worked well The SVX is a different pump than Outback. |
None of the parts..pulley, long bolt, bracket, will switch over?
last time I talked to the local wrecking yard they had the belt tensioner parts. have you checked with any?
Thanks. I haven't checked compatibilities yet
I could still use those if I had to. But the Bracket is the big deal, and I can't find an SVX in an Arizona yard yet. His bracket is massively different according to the subaruparts.com, and looks lie it must be on the other side of the engine.
I've got the bracket and stuff on my parts car. Problem is it's buried under 4 feet of snow. The shipping might be expensive to Arizona but I'll check on it if you'd like.
Just to update, the SVX power steering bracket is unique to the SVX and nothing else will work without a significant amount of modification.
Thanks Nate. I've looked back and forth through the subaru site, and can easily confirm that.
have you found something yet?
If not I will check with my local yard today, been planning on looking over what they have anyway. |
