Old 11-06-2013, 05:49 PM
ShiuludeSVX's Avatar
AAAAGh I broke one
Under the Intake Plenum there are 3 vacuum switches. I have sheered off one of the vacuum ports on 1 switch. It is the switch on the back right side of the assembly. There are no markings on this switch, and it is in a metal sandwich.
Please identify it {picture} and lemme know if it is interchangeable part with any other vehicle.
Thanks folks.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 11-06-2013, 09:41 PM
davew833 davew833 is offline
Re: AAAAGh I broke one
If you can't find a replacement, JB weld works wonders. You could also drill the hole out slightly (and carefully!) and insert a short length of metal tubing and then put a little JB weld around it to seal/hold it in place. I did that when I broke off a similar fitting when replacing my vacuum hoses last fall.
davew833@yahoo.com
Former 6-time SVX owner
Old 11-07-2013, 01:13 PM
q-bond will fix that thing up. it works better than jb on plastic.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
bishop bishop is offline
I used super glue on mine after cutting off the bit of hosing it was stuck in.
Old 11-07-2013, 01:34 PM
I could do that, but I was hoping to find one on another car to pull off intact. Ebay has droves of them, and the Miata Purge Solenoid looks to be the right one by appearance, but I don't want to put something in that goes off at the wrong value.
The Worm
_______________
No Mods, 33K Miles
Old 11-07-2013, 11:56 PM
Similar vintage legacys also used them.
Old 11-08-2013, 10:47 AM
Problem is if you pull another intact one that's the same age it will also be similarly brittle.
davew833@yahoo.com
Old 11-08-2013, 09:22 PM
Yeah. So, I did the JB Weld fix, and got it back in play.
I have the engine out for the Flexplate, so a few things are getting found, and remedied.
But it's a good opportunity to take care of those things without all the monkey work to get to them.
The Worm
_______________
No Mods, 33K Miles
