Sun roof tired
Is this an on going problem . I rarely open the sun roof but when I do I have to give it a little push up to get it started . It closes water tight and opens all the way and closes easily too. Any ideas how to lube it or to tighten it up? Have not been on here in a while so I have a few small issues to get fixed.
Re: Sun roof tired
Yes, its very normal. You will have to open it, clean off the track of all the old grease as best you can. Then use silicone spray lubricant on the track and all should be as new. I have been too lazy to get to doing it in mine. Can't use it 6 months out of the year here anyway
Re: Sun roof tired
Put some silicone libricant,(or sil-glyde from NAPA, Auto Zone)), around the rubber gasket of the sunroof panel. I use iSil-Glide on all my rubber gaskets to keep them lubricated and the doors from freezing in cold weather
It's intersting, on my pearlie, it I wanted to open the sunroof while the car was stopped, I would have to give it that initial "nudge". If I was travelling a highway speed, I could open it without any problem. The problemseems to be the initial friction between the gasket and the roof panel for the initial tilt. .
Re: Sun roof tired
Thanks when the weather get back to the 60's I will work on it . I thought it was just old and too tired like me <LOL>
Re: Sun roof tired
silicone paste to the weather strip is the way to go
charlie |
Re: Sun roof tired
lol I'm glad I found this thread. All 3 of my SVX's have lazy sunroofs I've just been too lazy myself to do anything about it
Meow |
