Old 03-20-2020, 06:15 AM
elemgee elemgee is offline
Where Is the EGR Control Valve Located?
I just bought a new EGR control valve solenoid thinking I'd use it as a guide to locate the original one on the engine. After looking around the engine for 20 minutes I dont see it, but I did come across a diagram that shows that its under the passenger side of the rear intake manifold (I tried to copy the diagram here but couldn't).
Is that correct; that I'd need to remove the intake manifold to get to the valve?
Thanks.
Larry
Old 03-20-2020, 10:44 PM
Re: Where Is the EGR Control Valve Located?
Hi EGR Solenoid and purge solenoid are under the manifold above cylinder 3&5
ive done it without removing the manifold
Old 03-27-2020, 01:39 PM
Thanks for the response. Can you give me some pointers for replacing it without removing the manifold? Thanks.
Larry
Old 05-29-2020, 04:43 PM
decalsvx decalsvx is offline
'96 SVX LSi needs EGR valve and hoses. Where did you get your EGR?
Old 06-11-2020, 11:07 AM
Question Re: Where Is the EGR Control Valve Located?
I'm looking for an EGR valve, part no. 14774AA500; if you found one, where?
Old 06-11-2020, 12:00 PM
irox irox is offline
This one?
https://www.amazon.com/Genuine-Subar.../dp/B00U0FIPIY
Although the picture looks different to the one you posted in another thread. Seems to be widely available, parts.subaru.com, ebay, etc. seem to have that part available.
Old 06-11-2020, 03:22 PM
Subaru oldtimer Subaru oldtimer is offline
You can still get this part# new from Subaru... retail is not cheap however. $100 plus.
Rick
1996 SVX LSI Bordeaux Pearl 222.600 and going
