Old 12-14-2013, 01:55 AM
danielparker danielparker is offline
JDM TCU Wanted
Hi,
I have damaged my TCU (Transmission Control Unit) and need a 'new' one..
My SVX is a Japanese Import, so I need another from a JDM model.
Can anyone help?..
Old 12-14-2013, 02:44 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: JDM TCU Wanted
Wow, that looks unusual - anyone else got the english equiv. (and what does it mean?).
Old 12-14-2013, 11:42 PM
Re: JDM TCU Wanted
Its two errors.. one says 'Diff Lock'.. and I don't know what the other says.
I have fixed my TCU (Damaged track caused by a modification I was doing), so the pressure is off finding one.
Daniel
Old 12-15-2013, 11:58 AM
Crash_Bandit Crash_Bandit is offline
Re: JDM TCU Wanted
The kana says "sentaa difurakku".
So most likely center differential lock is what it means.
-Ash
96 Polo Green - Daily Driver
92 Teal Green - Restoration in progress
Old 12-25-2013, 10:35 AM
ShaneHobson ShaneHobson is offline
Re: JDM TCU Wanted
Confirmed by checking my NZ instrument cluster.
It says Diff Lock in the same location.
Old 04-04-2020, 09:06 AM
SURTEESS's Avatar
Re: JDM TCU Wanted
Shane,
are you trying to do a switch in order to get diff lock working when you want manually ?.
It would be interesting to know what the wiring would be in order to do that.
Rate This Thread:
