  #91
Old 06-29-2010, 08:54 PM
green_eyed_lady's Avatar
green_eyed_lady green_eyed_lady is offline
Re: SVX Parts Central is open for business
Originally Posted by Hocrest View Post
To answer your other question, an AWD trans can not simply go into a FWD car.
You would need to use parts from your FWD trans to convert the AWD trans and eliminate the tailhousing where the AWD is.
The key word here is SIMPLY. Tom changed over Wikedjuggalo's fwd to awd, but you'd have to talk to one of them to get the details and pricing information.
Diana
1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint
Old 06-29-2010, 11:07 PM
If your ring gear sheered, I do have a good ring and pinion from a fwd. the spider gears are bad but that isn't too common. Also, shipping would not be bad for just sending the ring gear and pinion shaft...
Old 06-29-2010, 11:21 PM
Wikedjuggalo's Avatar
Rebuilding
It still hurts thinking of the pricing I kid.. It was probably not enough for the great work.
Simply you need a rear subframe is the big piece missing. I went 5spd so no TCu for me but you would need a AWD TCU.
Old 06-29-2010, 11:46 PM
Or you can just weld some metal into the FWD subframe and drill a hole for the rear diff studs and nuts like I saw some idiot do on youtube when he converted a fwd to AWD manual and turboed the car.
Old 06-30-2010, 06:45 AM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
Thanks for all the responses! I am curious as to where the 4.44 gears come from. Is there an impreza tranny that has a lower gear ratio than the stock fwd?
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 06-30-2010, 07:37 AM
Ther is a lot on here about the "4.44 swap" procedure. The tranny comes from certain years of Outbacks (again, I don't know the specifics but I'm sure you could easily find out) and you have to swap out the rear end gears for the LSD, but it's become the most common way to "fix" a blown stock SVX tranny. It takes about a day if you know what you're doing and the trannys are relatively inexpensive and plentiful.
Diana
Old 06-30-2010, 07:40 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Shoot--I have a bad 94 FWD tranny in storage in Oklahoma that has a good diff. You should be able to find one like that somewhere in TX--hopefully close to you.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 06-30-2010, 08:52 AM
Rebuilding
The FWD is a 3.70 where as the stock AWD SVX is 3.54. All FWD in the US is 3.70
Old 06-30-2010, 11:11 AM
But the front diff gears out of any 4EAT will go into the FWD tranny....but 4.44's in a FWD will be a tire spinning beast...
Old 06-30-2010, 03:23 PM
which will shortly there after grenade your front diff
